KICKR BIKE v1 (2019) Product Information & FAQ
KICKR BIKE v1 smart bike, side view
Download the Wahoo App
The Wahoo Fitness app keeps your BIKE up to date and leverages your smartphone to record basic workout information, delivering data-driven power that fuels your training and fitness goals. Get the app now to set up your KICKR BIKE and get cranking.
Design Specifications
  • Part Number: WFBIKE1
  • Shipping Dimensions: 54" x 14" x 35" (135 x 34 x 88 cm)
  • Weight: 93 lbs (42 kg)
  • Power Requirements: 100-240V, 50/60 Hz, 2.5A Max
  • Drivetrain: Belt Drive
  • Resistance Type: Electromagnetic and Enhanced Motor
  • Accuracy: + / - 1%
  • Connectivity: BLE, ANT+, ANT+ FEC
  • KICKR HEADWIND Compatible: Yes
Compatibility
User
  • User Height Range: 5 feet (152 cm) to 6 feet 4 inches (193 cm)
  • Max User Weight: 250 lbs (113 kg)
  • Crank Arm Lengths: 165, 167.5, 170, 172.5,175
Connectivity
  • Bluetooth Low Energy (BLE) 4.2
    • FTMS - power, speed, cadence, and control
    • CPS - power, speed, and cadence
  • ANT+
    • FE-C - power, speed, cadence, and control
    • PWR - power, speed, and cadence
Device
  • Minimum maintenance and use of the KICKR BIKE V1 requires a device capable of connecting to the KICKR BIKE V1 via the Bluetooth low energy (BLE) 4.0 or higher protocol and of running the Wahoo app.  See the Wahoo app in Apple or Google Play stores for current minimum device operating system requirements of the Wahoo App.
  • Compatibility with other devices or apps is dependent on the connectivity/minimum operating system requirements of the desired app.
Third party apps
In The BoxKICKR BIKE box contents: main assembly, rear stabilizer legs, handlebar, seatpost, 5mm bolts, Allen wrenches, power adapter
Caution: use of third party power adapters not supplied by Wahoo Fitness may cause permanent damage to KICKR BIKE.
Core Features
  • Accurate power measurement of +/- 1% with up to 2200W of resistance.
    • Reported - Power, Speed, Distance and Cadence
      • Measured - Power and Cadence
      • Simulated - Speed and Distance
  • Customized fit, shifting and gearing to match your outdoor bike
    • Shimano, SRAM, and Campagnolo road shifter configurations
    • 9-13 speed gearing configurations
  • Real-time physical grade changes for immersive and realistic rides.
  • Virtually silent operation
  • Control with the Wahoo app
  • Control with an ELEMNT computer
  • Third party app control
Using a KICKR BIKE
FAQ
How much space does a KICKR BIKE occupy when fully extended?
Do I need to spindown or calibrate the KICKR BIKE PRO?
Why isn't my KICKR BIKE PRO level at zero tilt?
Troubleshooting
For steps to troubleshoot common concerns, see
