KICKR BIKE Fit
KICKR BIKE supports two different options to provide the perfect fit: a Basic Fit and a Professional Fit.
After you complete the initial setup of your KICKR BIKE, you will be prompted to enter your bike fit measurements in the Fit Wizard.
Alternatively, to navigate to the Fit Wizard after your initial setup of the KICKR BIKE, please navigate to the Wahoo app, select your KICKR BIKE from the Devices tab, select the preferred Bike profile, choose View/edit profile, scroll to the bottom of your profile, and select Start fit wizard. You should then be prompted with the following options:
- Basic Fit
enter your inseam length and preferred riding position
- Professional Fit
enter the values from a GURU, Retul, or Trek branded fit session
In each case, the Wahoo app will produce precise position measurements for the center mast, fore/aft extensions, and steerer and seatpost. You can then tweak these values and record any changes to them into the app so you can remember your perfect fit if there is another rider in the household.
