This page applies to KICKR v6 released in 2022 featuring WiFi Direct Connect,
KICKR AXIS Stabilization and improved thru axle compatibility.
Please contact support for questions on older versions.
Download the Wahoo App
The Wahoo app keeps your trainer up to date and leverages your smartphone to record basic workout information, delivering data-driven power that fuels your training and fitness goals. Get the app now to register your KICKR. |
- Part Number: WFBKTR122
- KICKR Version: 6 (produced starting September 2022)
- Dimensions (legs open): 20" x 28" x 17" (51 cm x 71 cm x 43 cm)
- Dimensions (legs closed): 20" x 9" (51 cm x 23 cm x 43 cm)
- Weight: 47 lbs (21.3 kg) Unboxed
- Flywheel Weight: 16 lbs (5.5kg)
- Drivetrain:
- Out of Box: 11 Speed Cassette
- With Purchase and Installation of New Cassette: 8/9/10 Speed SRAM/Shimano
- KICKR CLIMB Compatible: Yes
- KICKR HEADWIND Compatible: Yes
- Cadence: Yes (integrated)
- Front Wheel Block: Not needed
- Resistance Type: Electromagnetic
- Accuracy: +/- 1%
- Maximum Simulated Grade: 20%
- Maximum Power Output: 2200 Watts
- Connectivity: Wi-Fi, Bluetooth®, ANT+, ANT+ FEC
- Wireless Software Updates: Yes
- 3rd Party Power Meter Support: Yes
- Devices: iOS, Android, PC (Mac and Windows)
- Max User Weight: 250 lbs (113 kg)
- Power Requirements: 100-240V~1.5A 50-60 Hz using supplied AC adapter\
REALISTIC RIDE FEEL
- KICKR’s professional-grade high inertia 16lb flywheel and AXIS feet combine to provide an ultra realistic ride feel.
CONTROLLED RESISTANCE
- When connected to your smartphone, tablet, computer or GPS bike computer, KICKR automatically sets and adjusts your resistance based on the software or route.
KICKR AXIS FEET
- Customizable cushioned feet respond to tempo and body position changes, mimicking the side-to-side movement experienced riding outdoors.
PROFESSIONAL GRADE DURABILITY
- Robust steel construction ensures the KICKR stays in place while you crank out the watts and stands up to years of heavy use.
SEAMLESS CONNECTIVITY
- Offering a robust 2.4 GHz Wi-Fi connection, up to 3 Bluetooth Connections, a direct connect port and ANT+/ANT+FE-C compatibility, KICKR smart trainers pair to most devices and applications so you have the most control over your training and ride data.
Compatibility
User
Bicycle frame
See Bicycle Frame Compatibility [KICKR] for bicycle frame compatibility.
Bicycle drivetrain
See Drivetrain Compatibility for KICKR, CORE, and MOVE trainers for bicycle drivetrain compatibility
Device/App
See Device Compatibility for Wahoo smart trainers [KICKR] for general device/app compatibility.
See Trainer App Compatibility for a list of compatible third party apps.
In the box
- KICKR
- AC power adapter
- Quick release skewer (*pre-installed)
- Disc Brake Caliper Spacer (install on break to prevent pads sticking)
- 1.8mm axle spacer (for use with 10 speed cassettes)
- Adapter A - Drive side adapter For 130mm and 135mm quick release (*pre-installed)
- Adapter B - Reversible hub spacer for 130mm and 135mm quick release (*pre-installed)
- Adapter C - Drive side adapter for 12x142mm and 12x148mm thru axle
- Adapter D - Hub spacer for 12x142 thru axle
- Adapter E - Hub spacer for 12x148mm thru axle
For in depth instructions, see the article on setting up your KICKR Smart Trainer.
Care and Maintenance
The Wahoo KICKR requires minimal cleaning and maintenance if dirt or grime collects. If cleaning is needed, clear any debris and use a moist, soft cloth to wipe surfaces, avoiding dripping moisture into any part of the KICKR itself. Also avoid using strong cleaning agents as these may damage or reduce the lifespan of your KICKR.
