KICKR v5 (2020) Smart Trainer Information & FAQ
The 2020 version of the KICKR Smart Bike Trainer delivers a realistic ride feel and precise power with the addition of KICKR AXIS Action Feet and improved power accuracy of +/- 1%. The KICKR Smart Bike Trainer for cycling continues to provide the best-in-class indoor smart trainer design with carbon steel body for durability and stability, to hold up to the demands of all types of cyclist. Its unmatched compatibility expands to include three simultaneous Bluetooth connections for a trouble-free start to your workout. Get the immersive, game changing indoor riding experience when you pair with our KICKR CLIMB Indoor Grade Simulator and Bluetooth & ANT+ controlled KICKR HEADWIND Smart Fan.
Download the Wahoo App
The Wahoo app keeps your trainer up to date and leverages your smartphone to record basic workout information, delivering data-driven power that fuels your training and fitness goals. Get the app now to register your KICKR v5.
KICKR v5 (2020) Design Specifications
  • Part Number: WFBKTR120
  • KICKR Version: 5 (produced starting August 2020)
  • Shipping Weight: 55 lb
  • Box Dimensions: 26"L x 12"W x 22"H
  • Country of Origin: Vietnam
  • Product Dimensions: 20x28x17 in // 51x71x44 (legs open)
  • Weight: 47 lb // 22 kg
  • Drivetrain: Belt Drive
  • Accuracy: +/- 1%
  • Wireless Software Updates: Yes, via the Wahoo Fitness app
  • Connectivity: ANT+ FEC, Bluetooth
  • Max User Weight: 250lbs // 114 kg
  • Flywheel Weight: 16 lb // 7.3 kg
  • Maximum Simulated Grade: +20
  • Minimum Simulated Grade: -10
  • Rear Wheel Size: 24" RD / 24" MTB / 650c RD / 26" MTB / 700c RD / 650b MTB / 29" MTB
  • Cassette: Included 11 Speed with 11-28 ratio
  • Adapters: Included
  • KICKR CLIMB Compatible Yes
  • RPM Speed & Cadence: Not Required
  • Front Wheel Block: Not Required
  • Disc Brake Clearance: Yes
In the Box
  • KICKR v5 (2020) Smart Trainer
  • AC Power Adapter
  • Quick Release Skewer
  • Disc Brake Caliper Spacer
  • 1.8mm Cassette Spacer
  • Drive Side Adapter for 12x142 and 12x148 Thru Axle
  • Reversible hub spacer for Thru Axle
  • AXIS Stiff and Easy Feet
  • SIDE-TO-SIDE MOVEMENT WITH KICKR AXIS FEET
    • The new KICKR AXIS feet enhance the ride feel of the KICKR Smart Trainer by mimicking the side-to-side movement experienced riding outdoors. These feet allow up to 5 degrees of movement and so the KICKR can respond more naturally to the rider tempo and body position changes. The KICKR includes a set of KICKR AXIS feet with three stiffness options to truly tune your ride to your unique riding style.
  • +/- 1% POWER ACCURACY
    • Enhanced power accuracy to provide accurate power measurement of +/- 1% and generate up to 2200W of resistance.
  • CALIBRATION FREE
    • Through an automatic calibration process, KICKR continuously offers accurate and precise power without a manual process by the user.
  • OPTIMIZED FLYWHEEL TECHNOLOGY
    • KICKR features a 16lb flywheel specifically engineered to provide riders with a more precise inertia needed to recreate an outdoor ride feel while training indoors.
  • VIRTUALLY SILENT OPERATION
    • The belt motor drivetrain on the KICKR was designed specifically to provide a smooth and virtually silent riding experience.
  • CONTROLLED RESISTANCE
    • When connected to your smartphone, tablet or computer, KICKR automatically sets your resistance via your favorite app or software.
  • REALISTIC RIDE FEEL
    • The KICKR flywheel is innovative and proven technology that emulates the power and inertia experienced during outdoor riding. It provides the most realistic ride feel especially when using virtual riding/training platforms like SYSTM, Zwift, and Trainer Road.
  • 20% MAXIMUM GRADE SIMULATION
    • The resistance of the KICKR automatically adjusts to simulate climbs up to a 20% incline.
  • EASY APP SET-UP
    • Our simple and intuitive Wahoo Fitness app offers guided instructions on how to set-up the KICKR and pair your 3rd party apps and sensors to fine tune your ride.
  • THRU AXLE COMPATIBLE
    • The KICKR features 12x142 and 12x148 thru axle compatibility in addition to standard 130/135mm quick release. Click to find out if your bike is compatible.
  • DISC BRAKE CLEARANCE
    • The design of the KICKR's main mast ensures clearance for flat mount and disc brake equipped bikes.
  • ANT+, ANT+ FE-C AND BLUETOOTH CONNECTIVITY
    • ANT+ and Bluetooth capabilities allow it to connect to both smartphones and GPS devices simultaneously or separately. An ANT+ FE-C connection allows the KICKR to be controlled from any FE-C enabled device or application.
  • MULTIPLE SIMULTANEOUS BLUETOOTH CONNECTIONS
    • KICKR supports up to three simultaneous Bluetooth connections for a trouble-free start to your workout.
  • ADJUSTABLE HEIGHT BASED ON WHEEL SIZE
    • Ability to adjust the height of the KICKR to match your wheel sizing so that your bike is level and no front wheel block is necessary. Settings match 24", 650c, 700c, 26", 27.5", and 29" wheels.
  • LED INDICATOR LIGHTS
    • Visual confirmation that KICKR is powered, connected and transmitting via Bluetooth and / or ANT+.
  • PROFESSIONAL GRADE DURABILITY
    • Robust steel construction ensures the KICKR stays in place while you crank out the watts and stands up to years of heavy use.
  • MEASURES SPEED, DISTANCE, POWER, AND CADENCE
    • Get these vital cycling metrics on your indoor ride on the KICKR without connecting any extra sensors.
  • KICKR HEADWIND COMPATIBLE
    • KICKR HEADWIND brings innovative climate control to your indoor training experience. Pair to your KICKR and as your speed or heart rate increases, so will the fan speed.
  • ELEMNT BIKE COMPUTER COMPATIBLE
    • Connect the KICKR to any ELEMNT Bike Computer to relive rides or perform planned workouts.
  • KICKR CLIMB COMPATIBLE
    • When paired with the KICKR smart trainer, the KICKR CLIMB indoor grade simulator will match ascents up to 20% and descents up to -10% with physical grade changes. It takes your training to the next level - literally.
  • APP COMPATIBILITY
    • Works with popular training apps such as SYSTM and Zwift. For more details on which apps are compatible with the KICKR, download our in-depth KICKR app comparison chart.
  • THIRD PARTY POWER METER SUPPORT
    • Compatible with a third party power meter as another method of power measurement.
