Updated 2016, the ultimate indoor bike trainer, the Wahoo KICKR, is better than ever! Take the rear wheel off your bike and connect to the Wahoo KICKR for accurate power measurement, controlled resistance, open third-party software options, and the smoothest indoor riding on the market. Pain cave, meet your new best friend.
The Wahoo app keeps your trainer up to date and leverages your smartphone to record basic workout information, delivering data-driven power that fuels your training and fitness goals. Get the app now to register your KICKR v5. |
- Part Number: WFBKTR116
- Box Dimensions: 26"L x 12"W x 22"H
- Product Dimensions: 21" x 9" (54 cm x 23 cm) // 21" x 28" (54 cm x 71 cm) (legs open)
- Weight: 47 lbs (21.3 kg) unboxed
- Flywheel weight: 12.5 lbs lbs (6.6 kg)
- Drivetrain:
- Out of Box: 11 Speed Cassette
- With Purchase and Installation of New Cassette: 8/9/10 Speed SRAM/Shimano
- KICKR CLIMB Compatible: No
- KICKR HEADWIND Compatible: No
- Cadence: Requires cadence sensor
- Front Wheel Block: Not needed
- Resistance Type: Electromagnetic
- Accuracy: +/- 2%
- Maximum Simulated Grade: 20%
- Minimum Simulated Grade: -10%
- Maximum Power Output: 2000 Watts
- Connectivity: ANT+ FEC, Bluetooth, ANT+
- Wireless Software Updates: Yes (Wahoo App)
- Max User Weight: 250lbs // 114 kg
- 3rd Party Power Meter Support: Yes
- Devices: iOS, Android, PC (Mac and Windows)
- Power Requirements: 100-240V~1.5A 50-60 Hz
- Noise Level: 61 dB
Enhanced Ride Responsiveness
- Wahoo has developed new algorithms that accurately replicate sprints, intervals and hill climbs on virtual training platforms such as Zwift and Trainer Road. Each acceleration and deceleration will now feel more realistic than ever.
Reduced Operating Noise
- The quietest flywheel trainer on the market. At 61 dB you can hear your heart pounding and your legs throbbing.
Enhanced Power Accuracy
- Enhanced to provide accurate power measurement and generate up to 2000W.
Increased Maximum Grade
- Maximum percent adjusts to simulate up to a 20 degree incline.
LED Indicator Lights
- Visual confirmation that KICKR is powered, connected and transmitting via Bluetooth Smart and / or ANT+
ANT+, Bluetooth Smart, and ANT+ FE-C Connectivity
- ANT+ and Bluetooth Smart capabilities allow it to connect to both smartphones and GPS devices simultaneous or separately. An ANT+ FE-C connection allows the KICKR to be controlled from any FE-C enabled device or application, including products like Garmin bike computers.
Professional Grade Durability
- Robust steel construction ensures the KICKR stays in place while you crank out the watts and stands up to years of heavy use.
Controlled resistance
- When connected to your device, it automatically sets your resistance via your favorite app or software
Realistic ride feel
- The KICKR flywheel is innovative and proven technology emulates the power and inertia experienced during outdoor riding. It provides the most realistic ride feel especially when using virtual riding/training platforms like Wahoo SYSTM, Zwift, and Trainer Road.
Measures speed, distance, power, and cadence
- Get all your vital cycling metrics on your indoor ride. Cadence only available when paired with a Wahoo RPM Cadence Sensor that is included.
Third Party App Compatibility
- Works with popular training apps such as Zwift and TrainerRoad. For more details on which apps are compatible with the KICKR, download our in-depth KICKR app comparison chart.
- Compatible with a third party power meter.
Compatibility
User
Max User Weight: 250 lbs (113 kg)
Bicycle frame
See Bicycle Frame Compatibility [KICKR] for bicycle frame compatibility.
Bicycle drivetrain
See Drivetrain Compatibility for KICKR, CORE, and MOVE trainers for bicycle drivetrain compatibility
Device/App
See Device Compatibility for Wahoo smart trainers [KICKR] for general device/app compatibility.
See Trainer App Compatibility for a list of compatible third party apps.
In the Box
- KICKR v2 (2016) Smart Trainer
- AC Power Adapter
- Quick Release Skewer
- RPM Cadence Sensor
- Hydraulic Brake Pad Spacer
- 1.8mm Cassette Spacer
For in depth instructions, see the article on setting up your KICKR Smart Trainer.
Care and Maintenance
The Wahoo KICKR requires minimal cleaning and maintenance if dirt or grime collects. If cleaning is needed, clear any debris and use a moist, soft cloth to wipe surfaces, avoiding dripping moisture into any part of the KICKR itself. Also avoid using strong cleaning agents as these may damage or reduce the lifespan of your KICKR.
