Updated KICKR/CORE thru axle adapter installation
Revised KICKR/CORE 142 Adapters
In 2020, several bicycle manufacturers updated the thru axle interfaces of the frames of select bike models, making them incompatible with KICKRs version 3 [2017] through version 5 [2020] and all versions of KICKR CORE. Working closely with these bicycle manufacturers, Wahoo developed an updated set of adapters allowing compatibility with affected bicycles and the above Wahoo trainers, with the exception of KICKR v3 [2017] (the updated adapters below are not compatible with KICKR v3.
Bikes known to be affected:
  • Cervelo Disc frames: All
  • Giant Propel Disc 2021+
    Giant TCR Disc 2021+
  • Lauf Siegla
    Lauf True Grit
  • Rondo Ruut AL2: 2021+
  • Trek Domane 2020+
    Trek Madone 2020+
    Trek Checkpoint Carbon 2021+
    Trek Emonda 2021+
    Trek Top Fuel 2021+
  • Ventum thru axle frames: All
Updated thru axle adapters are available for purchase on our website.
Please retain the legacy/stock adapters for future use with 148mm thru axle and QR bikes.
Original and New Parts
Notes
  • Part 4 replaces the original non-drive side KICKR 142/148 adapter (Part 1).
  • Part 5 or Part 6 replaces the original lock nut (Part 2).
    • Part 5 (longer) should be installed when using the stock Shimano HG11 or Campagnolo compatible freehub bodies.
    • Part 6 (shorter) should be installed when using the SRAM XDR compatible KICKR freehub body.
  • Part 7 replaces the original drive side spin cap (Part 3).
Tools required
  • Cassette lockring tool
  • Chain whip
  • 14mm cone wrench
  • 17mm cone wrench
Instructions
  1. Remove the existing non-drive side QR or thru axle adapter.
  2. Remove the existing drive side QR adapter or thru axle spin cap.
  3. Remove the cassette (Cassette removal/installation instructions).
  4. Remove existing freehub lock nut (Freehub removal/installation instructions)
  5. Install new chamfered freehub lock nut,(Parts 5 or 6 above, depending on freehub body type), tightening to finger-tight + 1/4 turn.
  6. Reinstall the cassette.
  7. Install the new 142 non-drive side adapter.
  8. Install the new chamfered drive side spin cap.
Because of the wide variety of bicycle makes and models available, Wahoo cannot guarantee KICKR's compatibility with all bikes.  While Wahoo has conducted tests on KICKR compatibility with certain bikes and makes note of any "Known Incompatible Bikes" on its website, it is important to note that list is not exhaustive. The KICKR end user is ultimately responsible for ensuring that his or her bike frame is compatible with the KICKR such that damage to the bike frame does not result from using the trainer.  If potential purchasers are unsure whether their bike would be compatible, Wahoo recommends visiting a local Wahoo retailer to test a bicycle’s fit before purchasing.  See https://www.wahoofitness.com/store-locator.
