KICKR v4 (2018) Smart Trainer Information & FAQ
Building on the proven success of Wahoo’s line of KICKR Smart Trainers, the 2018 edition delivers a virtually silent experience and a specially engineered, heavier flywheel to provide cyclists with the exact inertia they need to recreate the feeling of riding outdoors. The KICKR continues to provide the best in class indoor smart trainer design with carbon steel body for durability. Its unmatched compatibility expands to include our new indoor grade simulator, the Wahoo KICKR CLIMB, and our new Bluetooth and ANT+ powered fan, the KICKR HEADWIND. The KICKR includes an 11-speed cassette for easy setup and an RPM cadence sensor.
Download the Wahoo App
The Wahoo app keeps your trainer up to date and leverages your smartphone to record basic workout information, delivering data-driven power that fuels your training and fitness goals. Get the app now to register your KICKR v5.
  • Part Number: WFBKTR118
  • KICKR Version: 4 (produced starting July 2018)
  • Box Dimensions: 26"L x 12"W x 22"H
  • Product Dimensions: 20"L x 9"W x 17"H // 20"L x 28"W x 17"H (legs open)
  • Weight: 47 lbs (21.3 kg) unboxed
  • Flywheel weight: 16 lbs (7.5 kg)
  • Drivetrain:
    • Out of Box: 11 Speed Cassette
    • With Purchase and Installation of New Cassette: 8/9/10 Speed SRAM/Shimano
  • KICKR CLIMB Compatible: Yes
  • KICKR HEADWIND Compatible: Yes
  • Cadence: Requires cadence sensor
  • Front Wheel Block: Not needed
  • Accuracy: +/- 2%
  • Connectivity: ANT+ FEC, Bluetooth, ANT+
  • Wireless Software Updates: Yes (Wahoo App)
  • Max User Weight: 250lbs // 114 kg
  • OPTIMIZED FLYWHEEL TECHNOLOGY
    • KICKR features a 16lb flywheel specifically engineered to provide riders with a more precise inertia needed to recreate an outdoor ride feel while training indoors.
  • VIRTUALLY SILENT OPERATION
    • The belt motor drivetrain on the KICKR was designed specifically to provide a smooth and virtually silent riding experience.
  • CONTROLLED RESISTANCE
    • When connected to your smartphone, tablet or computer, KICKR automatically sets your resistance via your favorite app or software
  • REALISTIC RIDE FEEL
    • The KICKR flywheel is innovative and proven technology that emulates the power and inertia experienced during outdoor riding. It provides the most realistic ride feel especially when using virtual riding/training platforms like Wahoo SYSTM, Zwift, and Trainer Road.
  • 20% MAXIMUM GRADE SIMULATION
    • The resistance of the KICKR automatically adjusts to simulate climbs up to a 20% incline.
  • +/- 2% POWER ACCURACY
    • Enhanced power accuracy to provide accurate power measurement of +/- 2% and generate up to 2200W of resistance.
  • THRU AXLE COMPATIBLE
    • The KICKR features 12x142 and 12x148 thru axle compatibility in addition to standard 130/135mm quick release.
  • DISC BRAKE CLEARANCE
    • The design of the KICKR's main mast ensures clearance for flat mount and disk brake equipped bikes.
  • ANT+, ANT+ FE-C AND BLUETOOTH CONNECTIVITY
    • ANT+ and Bluetooth capabilities allow it to connect to both smartphones and GPS devices simultaneously or separately. An ANT+ FE-C connection allows the KICKR to be controlled from any FE-C enabled device or application.
  • MULTIPLE SIMULTANEOUS BLUETOOTH CONNECTIONS
    • KICKR supports up to three simultaneous Bluetooth connections for a trouble-free start to your workout.
  • ADJUSTABLE HEIGHT BASED ON WHEEL SIZE
    • Ability to adjust the height of the KICKR to match your wheel sizing so that your bike is level and no front wheel block is necessary. Settings match 24", 650c, 700c, 26", 27.5", and 29" wheels.
  • LED INDICATOR LIGHTS
    • Visual confirmation that KICKR is powered, connected and transmitting via Bluetooth and / or ANT+
  • PROFESSIONAL GRADE DURABILITY
    • Robust steel construction ensures the KICKR stays in place while you crank out the watts and stands up to years of heavy use.
  • MEASURES SPEED, DISTANCE, POWER, AND CADENCE
    • Get these vital cycling metrics on your indoor ride on the KICKR without connecting any extra sensors
  • KICKR HEADWIND COMPATIBLE
    • KICKR HEADWIND brings innovative climate control to your indoor training experience. Pair to your KICKR BIKE and as your speed or heart rate increases, so will the fan speed.
  • ELEMNT BIKE COMPUTER COMPATIBLE
    • Connect the KICKR to any ELEMNT Bike Computer to relive rides or perform planned workouts.
  • KICKR CLIMB COMPATIBLE
    • When paired with the KICKR smart trainer, the KICKR CLIMB indoor grade simulator will match ascents up to 20% and descents up to -10% with physical grade changes. It takes your training to the next level - literally.
  • THIRD PARTY APP COMPATIBILITY
    • Works with popular training apps such as Wahoo SYSTM and Zwift. For more details on which apps are compatible with the KICKR, download our in-depth KICKR app comparison chart.
  • THIRD PARTY POWER METER SUPPORT
    • Compatible with a third party power meter as another method of power measurement.
Compatibility
User
Max User Weight: 250 lbs (113 kg)
Bicycle frame
See Bicycle Frame Compatibility [KICKR] for bicycle frame compatibility.
Bicycle drivetrain
See Drivetrain Compatibility for KICKR, CORE, and MOVE trainers for bicycle drivetrain compatibility
Device/App
See Device Compatibility for Wahoo smart trainers [KICKR] for general device/app compatibility.
See Trainer App Compatibility for a list of compatible third party apps.
In the Box
  • KICKR v4 (2018) Smart Trainer
  • AC Power Adapter
  • Quick Release Skewer
  • RPM Cadence Sensor
  • Disc Brake Caliper Spacer
  • 1.8mm Cassette Spacer
  • Adapter A - Drive side adapter For 130mm and 135mm quick release
  • Adapter B - Reversible hub spacer for 130mm and 135mm quick release
  • Adapter C - Drive side adapter for 12x142mm and 12x148mm thru axle
  • Adapter D - Drive Side Adapter for 12x142 and 12x148 Thru Axle
  • Adapter E - Reversible hub spacer for Thru Axle
For in depth instructions, see the article on setting up your KICKR Smart Trainer.
Care and Maintenance
The Wahoo KICKR requires minimal cleaning and maintenance if dirt or grime collects. If cleaning is needed, clear any debris and use a moist, soft cloth to wipe surfaces, avoiding dripping moisture into any part of the KICKR itself. Also avoid using strong cleaning agents as these may damage or reduce the lifespan of your KICKR.
