KICKR RUN Product Info, Specifications, and FAQ
Device Specifications
  • Part number: WFRUN1
  • Dimensions: 72x38x58 in // 183x97x148 cm [LxWxH]
    • Deck height: 12 in // 30 cm neutral, 18 in // 46 cm at max incline
    • Belt area: 60x22 in // 152x56 cm
    • Device shelf holds up to a 17 in // 43 cm laptop, weighing up to 15 lbs // 6.8 kg
  • Weight: 429 lbs // 195 kg
  • Connectivity: Bluetooth FTMS, Direct Connect, and Wi-Fi
  • Wireless software updates: Yes
  • Compatible devices: iOS, Android, PC (MacOS and Windows)
  • Max user weight: 250 lbs // 113 kg
  • Power Requirements: 120V, dedicated 15A circuit
  • Charging capacity: 1x USB-C 24W charging port
  • Max belt speed/pace: 4 min/mile (15 mph)
  • Max deck incline: 15%
  • Min deck decline: -3%
Requirements
Power
US Model
  • A dedicated 120V, 15 or 20 amp circuit and non-GFI/non-GFCI outlet and breaker.
    • A dedicated circuit is a direct wired connection from a single circuit breaker in the main distribution/breaker panel to only a single outlet.
    • If wiring a new dedicated circuit, we suggest the use of an HACR type circuit breaker.
  • A direct connection between the treadmill and that wall outlet*
    • You cannot use a surge protector / power strip between the wall and the treadmill.
    • *If an extension cord is to be used, it must be rated to a minimum of 15 amps, a maximum of 25 feet (7.6 meters) in length, and a single connection.
    • The power cord for the KICKR RUN is 5 feet (1.5 m), and the power plug receiver is located at the front right of the treadmill.
UK/EU Model
  • A dedicated 200-240V, 16 amp or 32 amp circuit using, as a minimum, a Type B MCB (miniature circuit breaker), though a Type C is recommended.
    • A dedicated circuit is a direct wired connection from a single circuit breaker (MCB) in the main distribution/breaker panel to only a single outlet.
    • Note: A 13 amp wall outlet is sufficient in combination with a dedicated 16 amp MCB breaker / circuit.
  • A direct connection between the treadmill and the wall outlet*
    • *If an extension cord is to be used, it must be rated to a minimum of 16 amps, a maximum of 7.6 meters in length, and a single connection.
    • The power cord for the KICKR RUN is 1.5 meters, and the power plug receiver is located at the front right of the treadmill.
For more details, see Power, space, and connectivity requirements for KICKR RUN.
Space
  • Surface area of the KICKR RUN
    • 176 x 86 in / 4.5 x 2 m [length x width]
  • Recommended open space around the treadmill (based on ASTM standard recommendation for safe operating space )
    • 80 in / 203 cm immediately behind the treadmill
    • 24 in / 61 cm on each of the three other sides
  • Vertical clearance for 24 in / 61 cm greater than the height of your tallest intended user
  • Temperatures:
    • Storage:  -22 - 140 F // -30 - 60 C
    • Operating : 20 - 95 F // -7 - 35 C
Connectivity
  • Required for setup and firmware updates
    • Wi-Fi or a cell > Wi-Fi hotspot (2.4GHz, channels 1-11)
    • cell
  • Required for connected general use
    • Bluetooth and cell data on a mobile device capable of running the Wahoo app for iOS or Android
User Manual
Download a copy of the KICKR RUN user manual here.
The KICKR RUN is delivered and installed in the room of your choice by a team of professional installers.  Setup is completed in the Wahoo app for iOS or Android by scanning the QR code on the front of the console.
For more details, see KICKR RUN Setup.
For more details, see KICKR RUN Features.
Physical Features
  • Manual controls
    • Speed and grade multi-stage paddles
    • RunFree button
    • 3x contextual app interaction buttons
    • Stop button
  • Power switch
  • Time of flight sensor
  • 2x standard water bottle holders
  • Laptop shelf with integrated tablet/phone holder (holds up to a 17 in // 43 cm laptop, weighing up to 15 lbs // 6.8 kg)
Safety Features
KICKR RUN offers a variety of safety features intended to prevent unintended belt movement and stop the belt immediately in the case of a fall.
  • Safety key (emergency stop)
  • Stop button
  • Impact-based cadence detection
For more details, see KICKR RUN Safety Features
Control Modes
Manual Control mode
The KICKR RUN supports traditional treadmill manual speed and grade control using the multi-stage control paddles.
For more details, see Manual control mode [RUN].
RunFree mode
RunFree mode is a button-selected mode that allows you to run freely, naturally changing pace and stride without having to manually adjust the KICKR RUN's belt speed. The KICKR RUN will automatically change the belt speed to match your pace and stride changes, keeping you in the middle of the deck.
For more details, see RunFree mode [RUN].
Planned (structured) Workout mode
The KICKR RUN offers automatic belt speed and grade adjustments when used with structured running workouts with dynamic pace and grade targets in the Wahoo app.
For more details, see Planned workout mode [RUN].
Other features
Auto-leveling
The KICKR RUN will automatically level the deck horizontally at startup using the linear actuators used for grade changes to accommodate slightly uneven floors and prevent the it from shifting while in use.
Terrain mode
The KICKR RUN can be set to slightly adjust the horizontal camber of the deck intermittently to simulate the variability of an outdoor running surface and mitigate the repetitive motion fatigue of running on a treadmill.
For more details, see Terrain simulation mode [RUN].
