Campagnolo Freehub Installation on KICKR v4 (2018)+, MOVE, or CORE
This page covers installation of the Campagnolo Freehub on KICKR v4 - v6 (2022), MOVE, and CORE.
The Campagnolo freehub for v1 (2014)/ v2 (2016) is no longer available.  Please see instructions for KICKR v1 (2014) and v2 (2016) if installing that freehub on those trainers.
There is no Campagnolo freehub available for v3 (2017) KICKR trainers.
Campagnolo freehubs compared: the black KICKR v4 (2018)+ / CORE version and the gold KICKR v1-v2 (2014-16) version
KICKR v1 to v6 side by side with how to identify each, e.g. v6 Wi-Fi and status light, v5 AXIS feet
Compatibility
Trainers
  • KICKR v4 (2018) - v6 (2022)
  • KICKR MOVE
  • KICKR CORE
Cassettes
  • Most* 10, 11, and 12 speed Campagnolo cassettes made in 2010 or newer, as well as SRAM and Shimano HG cassettes.
  • *Exclusions -- Not compatible
    • 13 speed -- (because of 10 tooth N3W freehub design)
    • 12 speed -- Super Record Wireless (10 tooth N3W freehub design)
    • 10 speed -- cassettes with 8 inner arms on any cog (except the last/outer/smallest cog) are NOT compatible (see image below)
       Campagnolo cassette cogs compared: 4 inner arms marked compatible, 8 inner arms marked incompatible
Included Components
Campagnolo freehub kit for KICKR v4+ / CORE: freehub body, two lockrings and an O-ring
Notes:
  • The Campagnolo freehub supports Campagnolo, Shimano, and SRAM cassettes, but the included spacers are not needed with Campagnolo cassettes.
  • The included lockrings are geared for use with Shimano/SRAM lockring tools like the Park Tool FR-5.2.
  • Alternatively, you may use the lockring included with your cassette (both Shimano/SRAM and Campy compatible lockrings are supported).
Required Tools
Installation Steps
  1. Start by using the chain whip (or chain vice, as pictured) and lockring tool to loosen the lockring and remove the existing cassette
    (skip this step if a cassette is not present, like in KICKR CORE initial setup).
    Chain vise holding the cassette on a KICKR while a lockring tool and adjustable wrench loosen the lockring
    Hand removing the lockring from the center of the cassette on the KICKR
  2. Use the 17mm cone wrench** to remove the existing original lock nut and freehub body. Hold the pulley with your free hand for stability.
    **KICKR v6 and updated replacement adapter kits come with lock nuts with 14mm wrench flats, rather than 17mm.
    Park Tool SCW-17 cone wrench on the freehub lock nut while one hand steadies the KICKR pulley
    Original freehub body on the KICKR axle with the lock nut being removed by hand
  3. Install the inner spacer. You can use either the spacer contained in the Campagnolo freehub  (ships on the inside of the side with the pawls) or the original inner spacer. While cosmetically different (the Campy freehub's is shiny), they remain mechanically identical. Do not use both.
    Bare KICKR axle with the inner spacer in place and an arrow showing it pushed onto the axle
  4. Check the center of the Campagnolo freehub for any overhang on the captive inner spacer. Adjust this spacer by hand to ensure it's flush all around, as shown below:
    Campagnolo freehub center spacer: overhanging spacer marked wrong, flush spacer marked correct
  5. Install the new Campagnolo freehub over the inner spacer, rotating counterclockwise (in the direction of the pawls) until flush against the pulley.
    Campagnolo freehub on the KICKR with arrows to rotate it and push it onto the axle
  6. Screw on the original lock nut and tighten with the 17mm cone wrench**, again holding the pulley with your other hand for stability. Tighten until snug, being sure to avoid applying excessive force.
    *KICKR v6 and updated thru axle adapter kits come with lock nuts with 14mm wrench flats, rather than 17mm.
  7. Park Tool SCW-17 cone wrench tightening the lock nut on the installed Campagnolo freehub
    Campagnolo freehub installed on the KICKR with the lock nut seated at its end
  8. Install the included spacer as needed for your cassette, along with any other spacers which came included with the cassette.
    Hand sliding a spacer onto the installed Campagnolo freehub before fitting the cassette
  9. Install your cassette on the freehub like shown in the video below (instructions start at 1:20):
You're now ready to mount your bike and get KICKN!
