KICKR v6 (2022) Firmware Release Notes
This page contains firmware update notes for the KICKR v6 which features WiFi and new AXIS feet for improved compliance, pictured above.
For installation, please note that firmware updates are now installed automatically over WiFi.
KICKR v6 Firmware 5.6.26 / WiFi 1.3.26 - 11 August, 2026
  • Updated: Bug fixes, connection and stability improvements
KICKR v6 Firmware 5.6.20 / WiFi 1.3.26 - 12 June, 2026
  • Updated: Bug fixes and stability improvements
KICKR v6 Firmware 5.6.13 / WiFi 1.3.26 - 1 June, 2026
KICKR v6 Firmware 5.4.29 / WiFi 1.3.26 - 2 December, 2025
  • Updated: WiFi connection improvements
KICKR v6 Firmware 5.4.29 / WiFi 1.3.21 - 21 November, 2025
  • Updated: Stability improvements
KICKR v6 Firmware 5.4.29 - 20 November, 2024
  • Updated: Optimizations and stability improvements
KICKR v6 Firmware 5.3.47 - 28 October, 2024
  • Updated: Zwift protocol version.
  • Fixed: Virtual shifting would not disable when Zwift disconnects.
  • Fixed: Auto-spindown errors when using virtual shifting in specific scenarios.
    • In the previous firmware versions, there was an issue with the trainer calculating the correct spindown values during the auto calibration process in certain scenarios when also using Zwift Virtual Shifting. The conditions could result in the trainer reporting "ghost" watts (watts while coasting), and could result in a power offset throughout the ride. If you are currently experiencing "ghost" watts, this firmware update will not immediately fix the issue on its own, but having updated to the current firmware, the  auto calibration process will fix the power offset over time without manual intervention. If you would like to resolve the power offset immediately, you can complete a factory spindown.
KICKR v6 Firmware 5.3.5 - 29 April, 2024
  • Fixed: 2000 watt power spike when switching between ERG/SIM
KICKR v6 Firmware 5.2.15 - 22 February, 2024
KICKR v6 Wi-Fi 1.0.12 - 3 February, 2023
  • Fixed: Zwift WiFi pairing issue
KICKR v6 Wi-Fi 1.0.11 - 31 January, 2023
  • Fixed: general stability improvements
KICKR v6 Firmware 5.0.14 / Wi-Fi 1.0.10 - 9 January, 2023
KICKR v6 Firmware 5.0.12  - 17 October, 2022
  • Fixed: Stability Improvements
KICKR v6 Firmware 5.0.9 / Wi-Fi 1.0.8 - 13 September, 2022
  • Automatic calibration
  • Wi-Fi and Direct Connect network connectivity
  • Wi-Fi and Direct Connect motion data and trainer control
  • BLE motion data and trainer control
  • ANT+ PWR
  • ANT+ FEC
  • Automatic Wi-Fi firmware updates
  • ERG mode easy ramp
  • Odometer
