For information on how to update ELEMNT ACE firmware, see Update firmware ELEMNT ACE, BOLT 3, or ROAM 3.
ELEMNT WG87-302909 - 10 November, 2026
- Fixed: Bug fixes and stability improvements.
ELEMNT WG87-302826 - 26 October, 2026
- On a 10 day rollout, complete by Nov 4.
- Reverted changes to speaker volume in WG85.
ELEMNT WG85-302826 - 29 September, 2026
- Fixed: Improved sensor connection reliability.
- Fixed: Battery optimizations to extend ELEMNT run time.
- Added: Increased maximum volume of the system audio.
ELEMNT WG77-302685 - 22 September, 2026
- Added: A redesigned home page in the Wahoo app gets you out riding faster. Load a route, pick a workout, and customize your data pages and profiles, all in one place, before you roll out or mid-ride.
ELEMNT WG77-302682 - 31 July, 2026
- Fixed: Bug causing users switching to the Polish Language to crash back to the set up screen.
ELEMNT WG77-302661 - 28 July, 2026
- Added: Ventilation training zones for Tymewear VitalPro users.
- Added: Polish as a device language option (on-screen text + turn-by-turn voice).
ELEMNT WG77-302543 - 24 June, 2026
- Fixed: Computer unresponsive to SRAM AXS shifter bonus buttons and Blip control.
ELEMNT WG77-302533 - 16 June, 2026
- Added: ELEMNT ACE now offers live data presentation and data recording with four new biometric sensors: CORE (core body temperature), FLOWBIO (sweat and sodium loss), hDrop (sweat and sodum loss), and TymeWear (breathing rate). Use the Wahoo app to add and configure data fields for these sensors on your ELEMNT bike computer. For more details, see the support articles linked below.
- Added: Sensor support for CORE body temperature sensors
- For more details, see Use CORE body temperature sensor with ELEMNT ACE, BOLT 3, and ROAM 3
- Added: Sensor support for FLOWBIO sweat sensors
- For more details, see Use FLOWBIO sweat sensor with ELEMNT ACE, ROAM 3, or BOLT 3
- Added: Sensor support for hDrop hydration sensors
- For more details, see Use hDrop hydration sensor with ELEMNT ACE, BOLT 3 AND ROAM 3
- Added: Sensor support for Tymewear ventilation sensors
- For more details, see Use Tymewear VitalPro Ventilation Sensor with ELEMNT ACE, BOLT 3 AND ROAM 3
ELEMNT WG77-302251 - 20 May, 2026
ELEMNT WG77-302241 - 13 May, 2026
Updated: Performance/Battery Improvements to address recent battery issues
ELEMNT WG77-302231 - 5 May, 2026
- Added: Komoot Live Sync feature
For more information, see Komoot Live Sync for ELEMNT ACE, BOLT 3, and ROAM 3
ELEMNT WG77-302141 - 15 April, 2026
ELEMNT WG77-302138 - 14 April, 2026
- Added: Updated Wind Dynamics (ELEMNT ACE)
Wind Dynamics gets a significant upgrade. Wind Impact is now the primary wind value — showing directly how much a headwind, tailwind, or draft is affecting your speed, no mental math required. New supporting fields including Potential Speed, Wind Grade, and Resistance Ratio give you a fuller picture of how wind and grade are shaping your ride.
A new dedicated Wind page brings all of this together in one place, and the Map page wind widget now shows Wind Impact (green for tailwind, red for headwind). Post-ride, your Wind Dynamics summary now includes a Resistance Ratio breakdown showing how much of your effort went toward fighting wind vs. climbing.
For more information, see ELEMNT ACE Wind sensor and Wahoo Wind Dynamics
ELEMNT WG77-302052- 27 March, 2026
- Added: USB access to completed activity .FIT files, enabled through a device settings toggle in the Wahoo app for latest ELEMENT devices.
- For more details, see Connect an ACE, BOLT 3, or ROAM 3 to a desktop/laptop computer
ELEMNT WG77-301861 - 12 December, 2025
- Added: Voice TBT directions in Japanese, Korean, Dutch, Thai, Portuguese, and Chinese languages.
- Note: Languages are mapped to your phone's system language settings, not a manual control on the computer or Wahoo app.
ELEMNT WG77-301810- 4 November, 2025
ELEMNT WG76-301724 - 21 October, 2025
- Added: Custom Waypoints on ELEMNT – Riders can now see and be alerted to custom waypoints like water stops, food, hazards, or rest areas added in Strava, Komoot, or Ride with GPS. For more details, see Custom Waypoints and POIs on ELEMNT ACE, BOLT 3, and ROAM 3.
- Smarter Ride Guidance – Waypoints appear on the map, cue sheet, or a dedicated Waypoints Page with alerts for name, distance, and elevation change. Riders can even route directly to a selected waypoint for a more direct path to their next stop.
- Flexible & Clear Views – Toggle waypoint visibility to keep maps uncluttered and ride with confidence, knowing all your planned stops and notes sync seamlessly to your ELEMNT.
- Note for Strava Users (Gen 3 Devices): To enable custom waypoints on Strava routes, riders must first update their device firmware, then reprocess routes by wiping routes from their device, syncing to Wi-Fi, deauthorizing and reauthorizing the Strava–Wahoo App connection, and re-downloading their route library. Full instructions here.
- Updated: Custom alerts can now be updated/changed during an active workout
- Updated: Software updates can no longer be installed during an active workout
- Fixed: Skin temperature data field is converted incorrectly
- Fixed: Summit Segments chevron colors on map can be different than the colors in the climb/elevation graph
- Fixed: Climb/elevation graph does not update when going off-route
- Fixed: Crash occurs when unpairing some bluetooth sensors that prompt for removing data fields
- Fixed: Sensor data is cut off when selecting sensors in the dashboard (ACE, ROAM3) using the physical buttons
- Fixed: The line color for the route ahead on the map page cannot be seen in dark mode
- Fixed: Summit Segments is not adhering to the selected climb detection setting when a route is loaded
- Fixed: Sort by Proximity does not properly sort routes (BOLT3)
- Fixed: Footer actions are not correct when adjusting volume control via touchscreen
- Fixed: Crash when viewing the sensor details page of certain sensors
- Fixed: Sensor discovery shows previously discovered sensors that are no longer available
- Fixed: Page title in status bar overlaps pagination indicators
- Fixed: Showing incorrect route loaded icon on map page when in dark mode
- Fixed: Radar lane can show up on passcode entry screen when a radar connects in the background
- Fixed: GPS is now restarted if it becomes unresponsive
ELEMNT WG76-301600 - 17 October, 2025
ELEMNT WG72-301600 - 9 September, 2025
ELEMNT WG72-301599 - 14 August, 2025
ELEMNT WG70-301599 - 5 August, 2025
Enhanced security measures
- Added: Pairing to a phone now requires a matched PIN code to be accepted on both devices to establish a secure connection.
- Added: Optional passcode lock – Protect your ELEMNT and personal data by adding a passcode; you can add, change and remove a passcode from the Device Settings menu on your ELEMNT computer.
- If a passcode is set, ELEMNT will be locked after powering on, or by manually locking from the Device Settings menu.
- Option to add the passcode lock has been added as a final step in the onboarding process.
- Passcode can be removed remotely using a currently connected instance of the Wahoo app.
- Factory reset now requires passcode verification, if enabled.
- For more details, see Device passcode lock for ACE, BOLT 3, and ROAM 3
- Updated: USB access is now disabled by default, and must be enabled via an Allow USB access toggle in Wahoo app > Devices > elemntcomputer > Settings
- Updated: completed ride FIT file are no longer accessible via USB
Map theme changes
- Added: New map layer that allows bike lanes to be enabled/disabled
- Updated: Map layers user interface
- Updated: Map theme has been adjusted to increase contrast, improve color variance, and remove visual clutter at certain zoom levels
- Updated: The order of the navigation chevrons and user history line on the map has been switched
User interface / notifications / data fields
- Added: Skin temperature is now available as a configurable data field and is recorded in FIT files
- Updated: Minor user interface adjustments in the Device Settings menu and its sub pages
- Updated: Ride started notification now shows which workout profile is currently being used
- Updated: Phone notifications indicator (red circle) in the status bar is no longer shown for system notifications
- Updated: Elevation, GPS Accuracy, and GPS Heading data fields on workout data pages now display "--" while acquiring a GPS signal
- Updated: Distance Remaining and Distance to Cue data fields on the map page are no longer shown until a GPS signal has been acquired
- Updated: Shifter battery data field has been updated for improved visibility
- Fixed: Pressing the up/down buttons to zoom on the map page now works before acquiring a GPS signal
- Fixed: Sensors that are no longer available are not shown in the Pair Sensor list
- Fixed: Elevation graph not fully visible along the y-axis
- Fixed: Selecting a route now returns you to the menu
- Fixed: Targets of some SYSTM workouts not being processed properly
- Fixed: Banner displayed when an approaching a Summit Segment climb now has the correct climb category color
- Fixed: Planned workouts with both power and cadence targets now show the correct minimum value in their corresponding data field
- Fixed: Banner is displayed confirming a planned workout has been loaded
- Fixed: Custom alerts that are set to trigger on lap no longer show an alert immediately upon starting ride
- Fixed: Wheel circumference setting now shows correct value for speed sensors
- Fixed: Gear visual data field on KICKR control page
- Fixed: When using TRACKR RADAR in the Auto light mode, the light no longer turns on automatically prior to the first vehicle detection
- Fixed: Various translations in multiple languages
- Fixed: Several crash conditions
ELEMNT WG49-301341 - 28 May, 2025
- Added: Voice turn by turn directions in French, German, Italian, and Spanish.
- Note: Languages are mapped to your phone's system language settings, not a manual control on the computer or app.
- Added: A notifications page in computer settings-- You can now scroll to the notifications page to review and manage system (software updates), sensors (low battery), or un-dismissed phone, message, or email notifications passed through from your phone.
- Added: On/off toggle for the digital bike bell on the Device Settings page
- Added: An extra step (now four) in the volume controls for the device speaker.
ELEMNT WG49-301249 - 5 May, 2025
- Added: A new Auto Max backlight mode.
- Added: Change elevation profile distances on Elevation or Map pages by tapping the profile.
- Unrouted: 2mi/2km (default), Total ride
- Routed: 2mi/2km (default), 20mi/20km, Route to go, Total route
- Added: Save/Modify Saved Locations for ACE in the Wahoo app.
- Improved: Significant improvements to battery life due to under-the-hood fixes for CPU efficiency, tuning of the Auto backlight mode, tweaks to screen animations, and more.
- Improved: Map page data fields slide out of the way when the map is unlocked for touch.
- Improved: Usability and readability improvements across all the menu pages.
- Improved: Overall stability of ACE
- Updated: Redesigned map layer menu
ELEMNT WG49-300973 - 14 April, 2025
- Fixed: Minor bug fixes and stability improvements
ELEMNT WG49-300972 - 10 April, 2025
ELEMNT WG34-300972 - 18 March, 2025
ELEMNT WG34-300970 - 11 March, 2025
- Updated: Metric speed abbreviation -- KPH > KM/H
- Fixed: Map page does not display all data fields
- Fixed: Strava Live Segments only show 50 segments
- Fixed: minor bug fixes and stability improvements
ELEMNT WG34-300965 - 21 February, 2025
- Fixed: minor bug fixes and improvements
ELEMNT WG34-300963 - 17 February, 2025
- Added: Feature - Route filtering & sorting
- Added: Feature - Adding, editing, and renaming Saved Locations
ELEMNT WG34-300753 - 21 January, 2025
- Improved: battery performance
ELEMNT WG32-300753 - 15 January, 2025
- Added: Computer and sensor low battery alerts at ride end
- Fixed: ANT+ trainer control issues
- Fixed: Strava Live Segments on map view missing
- Fixed: Heart rate and power zone colors
- Fixed: Elevation page 20 mi / km view only showing 15
- Fixed: Reversing route did not reverse turn by turn cues
ELEMNT WG32-300745 - 8 January, 2025
ELEMNT WG29-300745 - 19 December, 2024
- Added: Strava Live Segments feature
- Added: Elevation graph zoom levels for Elevation page
- when a route is selected:
- 2km/mi (default),
- 20km/mi,
- distance to go,
- total ride
- without a route:
- 2km/mi,
- total ride to this point
- Updated: Elevation graph for Maps page
- without a route
- 2km/mi
- with a route
- total route
- without a route
- Fixed: custom alerts beep missing when general workout alerts sound is enabled.
- Fixed: sounds missing when ACE powered on
- Fixed: minor bug fixes and UI improvements
ELEMNT WG29-300646 - 3 December, 2024
- Auto-update at startup for New ELEMNT ACE
ELEMNT WG27-300363
- Stock firmware on shipped ELEMNT ACE units.
