Compatible Trainers [SYSTM]
This is a list of known trainers and their compatibility limitations with the SYSTM app. For an overview of the different types of trainers that can be used with the SYSTM app, see What type of trainer can I use with the SYSTM app?
Blackburn
Tech Mag 6
Tech Fluid
Bkool
Bkool One
Bkool Smart Air Pro
Bkool Smart Go
Bkool Smart Pro
Bkool Smart Pro 2
Bowflex
C6 spin bike
  • Please note: This trainer does not seem to report power accurately to our app. If you have this issue, please contact Nautilus for service.
  • Please ensure that your smart bike's firmware is up to date following
    the manufacturer's instructions prior to connecting to the SYSTM
    app.  Once your firmware is up to date, app completely and launch SYSTM.
    be sure to shut down the bike's app completely and launch SYSTM.
  • If you're using the SYSTM app on iOS or Android, you will want to connect to your smart bike using Bluetooth.
  • If you're using the SYSTM app on Mac or Windows, you can choose to connect to Bluetooth if your computer is Bluetooth compatible*. You can choose to connect with ANT+ if you have an ANT+ USB dongle. (This is recommended if Bluetooth is not compatible).
  • *To determine if Bluetooth is compatible- launch the workout player in the app. If Bluetooth appears as ON, you should be able to connect. If Bluetooth is OFF, we recommend using an ANT+ dongle to connect your trainer.
    • For connection instructions using Bluetooth, click here.
    • For connection instructions using ANT+, click here.
A different model
BT Advanced Training Systems
Cascade
Fluid Pro
A different model
CatEye
CS-1000
Computrainer
CycleOps / Saris
Hammer (H1, H2, H3)
Magnus or M2
  • Please ensure that your smart bike's firmware is up to date following the manufacturer's instructions prior to connecting to the SYSTM app.  Once your firmware is up to date, app completely and launch SYSTM. Be sure to shut down the bike's app completely and launch SYSTM.
  • *To determine if Bluetooth is compatible- launch the workout playerin the app. If Bluetooth appears as ON, you should be able to connect. If Bluetooth is OFF, we recommend using an ANT+ dongle to connect your trainer.
Aluminum Rollers
Fluid2
Jetfluid Pro
Mag+
Magneto
SuperMagneto Pro
Wind
CycleOps 300/400
Phantom 500 Spin Bike
  • This bike will connect to the app and report power.  The app cannot control the resistance on this trainer.
Concept2
  • This bike will connect to the app and report power. The app cannot control the resistance on this trainer. Please note that when using Bluetooth, this bike will only report AVERAGE POWER to the app.  ANT+ connections are recommended for this trainer.
  • If you're using the SYSTM app on Mac or Windows, you can choose to connect with ANT+ if you have an ANT+ USB dongle.  Bluetooth is not recommended for this trainer.
  • Using SYSTM on iOS or Android is not recommended for this trainer.
  • There are special considerations for connecting this bike.
Echelon
  • The Echelon spin bikes use proprietary Bluetooth that is not compatible with the SYSTM app. You can use your trainer without connecting by following the instructions found here:
Elite
Direto / Direto II
Drivo
Arion Smart Digital B+
Qubo Digital Smart B+
Real Axiom B+
Rampa
Real E-Motion B+
Real Tour B+
Real Turbo Muin B+
Aluminum Rollers
Arion Mag Rollers
Arion Parabolic Rollers
Crono Fluid Elastogel Round
Crono Power Fluid
E-Motion Rollers
Fluid Primo
Nero
Novo Force / NF Power Pack
Novo Mag Froce
Novo Mag Speed Aluminum
Novo Power Mag
Novo Smart
Parabolic Rollers
Qubo Fluid +
Qubo Power Fluid
Qubo Power Mag
Kura
Misuro Blu Sensor
Qubo Power Mag Smart B+
Quick Motion Rollers
  • If you have a Misuro B+ unit for this trainer, please choose Misuro Blu Sensor from the list above.
  • If you do not have the Misuro unit, please choose the E-Motion rollers from the Elite trainer list (and the E-Motion power curve in the Virtual Watts settings in the app)
Feedback Sports
Omnium Rollers (Omnium No-Drive)
Other models
ICG
IC6
IC7
IC8
Inside Ride
E-motion Rollers
Jet Black
Z1 Fluid Pro
Z1 Fluid Trainer
Whisper Drive
M1 / M1 Pro
M5 / M5 Pro
S1
Keiser
Kreitler
4.5 inch, with 1/2 fan setting
3 inch, with no fan setting
2.25 inch, with 1/2 fan or no fan setting
Kurt Kinetic
  • ***Are not compatible with the iOS app.***
R1 (T7000)
Rock and Roll Control Trainer (T6500)
Road Machine Control Trainer (T6400)
Trainer modified with Control unit (T6300)
  • If you're using the SYSTM app on Android, you will want to connect to your smart bike using Bluetooth.  The trainers are not compatible with the iOS app.
Road Machine Control Smart (T6100)
Rock and Roll Control Smart (T6200)
Trainer modified with Control unit (T6000)
  • These trainers will connect to the app and report power.  The app cannot control the resistance on this trainer.
Rock and Roll Smart 2 (T2810)
Road Machine Smart 2 (T2710)
  • This trainer will connect using the InRide sensor that the unit is equipped with. Please ensure that your InRide sensor is a 3rd generation sensor. It should be green in color. The black sensors are earlier generations and are not compatible using this connection method. Please see choose the Kurt Kinetic Classic model that matches your trainer for connection instructions.
  • If you're using the SYSTM app on Mac or Windows, you can choose to connect using Bluetooth or ANT+. You will need an ANT+ USB dongle.
  • For connection instructions using Bluetooth, see Connecting a Smart (non-controllable) Trainer or Power Meter (Bluetooth)
  • For connection instructions using ANT+, see Connecting a Smart (non-controllable) Trainer or Power Meter (ANT+)
Rock and Roll (classic)
Road Machine (classic)
Lemond Revolution
Minoura
Kagura LST 9200
B60
LR240 Mini
LR340
LR540
LR760
LR960
LR970
M70
M80
V100
V130
V270
Peloton
Precor
Spinner Chrono Power
A different Precor spin bike
Revbox
Saris
SRM SmartIT
  • Please note: This trainer has not been tested with the SYSTM app. If you are having trouble connecting, please contact our support team.
Schwinn
IC6
IC7
IC8
  • Please note: These trainers do not accurately report power to the SYSTM app, but consistently report inaccurate data proportionally.
Another model
Sportscrafter
ZR0110
Tacx
Bushido Smart
Flow Smart
Genius Smart
Ironman Smart
Neo
Neo 2 / 2T
Neo 3M
Neo Bike
Satori Smart
Vortex Smart
Flux
Flux 2
Flux S
Blue Motion
Booster
Sirius
Blue Twist
Satori
Swing
Blue Flow
Blu Matic
I-Genius
  • Please note that some earlier models of the i-Genius will require an update to add FE-C. If the trainer cannot be updated, please look for connection instructions for the Tacx Genius.
Bushido T2970
I-Bushido
Traveltrac
Comp Mag+
Technique Pro Alloy Rollers
Tru Trainer Rollers
Tunturi
E60 Ergometer
  • Please refer to the trainer user manual for instructions to connect the trainer console to a third party app (SYSTM). Please note that the connections will show a trainer control icon, but this function is not supported by the app. This trainer will connect and report power, but resistance control must be done manually.
  • This trainer is not compatible with ANT+
Wattbike
Wattbike Atom
  • Please ensure that your smart bike's firmware is up to date using the the Wattbike Hub app.  Be sure to disconnect from the Wattbike Hub app and closing the app prior to connecting to the SYSTM app.
Wattbike Pro
  • The Wattbike Pro will only be compatible with the SYSTM app using the Head unit B. If you have the A unit, you will need to order the B unit from Wattbike.
  • Be sure to update your Wattbike's firmware.
  • To connect using Bluetooth: Ensure that your head unit supports Bluetooth. You should see the Bluetooth icon on the headunit. If you do not see the Bluetooth symbol, please see ANT+ connection instructions.
    1. Open the Wattbike Hub app on your device.
    2. Navigate to Settings screen on the Wattbike head unit.
    3. Tab to the Remote tab and ensure that Bluetooth is enabled.
    4. From the same screen, select Enable Bluetooth Programming Mode and then Enter. You will need to confirm this choice.
    5. From the Wattbike Hub app, select Just Ride and then, in the top right corner, select your Wattbike.
    6. When prompted, confirm activation of the head unit's Bluetooth. Select Yes.
    7. The Wattbike Hub app should confirm that the head unit is now connected. Select Activate.
    8. Close the Wattbike Hub App.
    9. On the Wattbike head unit, select Just Ride.
    10. Launch the SYSTM app and connect using the following instructions.
  • To connect using ANT+ (Mac and Windows only)
    1. This will require an ANT+ dongle (receiver) and a USB extension cable.
    2. From the Wattbike head unit, select ANT Channel. Set the Bike Power and Speed & Cadence channels to ON, and set the Wattbike to Standard.
    3. With your head unit on, start pedaling. This will allow the ANT+ signal to start broadcasting.
    4. Launch the SYSTM app and connect using the following instructions:
My trainer isn't listed
See What type of trainer can I use with the SYSTM app?
I have a power meter
See
I still need help
If your concern is unresolved or you have questions, please submit a support request and our support team will be happy to assist you further.
