Compatible Sensors [SYSTM]
For detailed instructions on how to connect your sensors, find your sensor on the chart below.  For trainer connections, please see Compatible Trainers [SYSTM].
Wahoo
Wahoo sensors are compatible with ANT+ or Bluetooth.
  • If you're using the app on iOS or Android, you will want to connect using Bluetooth.
  • If you're using the app on Mac or Windows, you can choose to connect with ANT+ if you have an ANT+ dongle, or with Bluetooth, if your computer is Bluetooth compatible.
4iiii
Connecting to the app
The 4iiii heart rate monitor is compatible as a heart rate monitor using ANT+ and Bluetooth. It is also compatible as an ANT+ to Bluetooth bridging device.
The Viiiiva can transmit power, cadence and speed from an ANT+ sensor, but will not transmit an FE-C signal. This means that the app cannot control a smart trainer that is connected through the Viiiiva HRM.
ANT+ to Bluetooth Bridge: Viiiiva
For instruction on how to use the Viiiiva heart rate monitor as an ANT+ to Bluetooth Bridge, please see Viiiiva Heart Rate Monitor: ANT+ to Bluetooth Bridge
Bontrager
Bontrager sensors are compatible with ANT+ or Bluetooth.
Garmin
Most modern Garmin sensors are compatible with ANT+ or Bluetooth. Some legacy sensors are ANT+ only. Check the back of the sensor for the Bluetooth icon to confirm.
Magene
The Magene Bike Speed/Cadence 2-in-1 Sensor is compatible with SYSTM using ANT+ or Bluetooth.
Each sensor needs to be configured to the type of sensor you would like to use by removing and replacing the battery.
  • When the light flashes red, the sensor is configured as a cadence sensor.
  • When the light flashes green, the sensor is configured as a speed sensor.If you're using the SYSTM app on iOS or Android, you will want to connect using Bluetooth.
If you're using SYSTM on Mac or Windows, you may choose to use Bluetooth or ANT+. ANT+ connections will require the use of an ANT+ dongle.
Polar
  • Polar sensors are Bluetooth compatible only. These sensors are not ANT+ compatible.
  • Only the H7, H9 and H10 (heart rate monitors) are compatible with SYSTM. The speed and cadence sensors are compatible.
  • Other models are not compatible.
ANT + > Bluetooth Bridge
  • The use of an ANT+ to Bluetooth bridging device is necessary to connect ANT+ power meters and trainers to the SYSTM app on iOS and Android.
  • To connect ANT+ devices to a PC or laptop, please use an ANT+ dongle.
  • In all other cases, we recommend purchasing compatible Bluetooth sensors. We cannot guarantee that the ANT+ to Bluetooth bridging devices will work effectively all the time.
Cable by NPE
For instructions on how to use the CABLE by NPE to connect ANT+ devices to the app using Bluetooth, please see The CABLE by NPE
Viiiiva by 4iiii
Another Brand
Connecting ANT+
To connect ANT+ sensors, please refer to the instructions found here: Connecting ANT+ Sensors
Connecting Bluetooth Sensors
Please follow the instructions found here: Bluetooth Sensor Connections
