Replace Battery for TRACKR SPEED
To replace the battery of the TRACKR Speed, remove the sensor pod from within the sensor mount.
  1. Rotate the battery door counter-clockwise, then lift and remove the battery door. A relatively thicker coin, like a US nickel or dollar coin works well for this purpose.
  2. Insert a new CR2032 battery positive (+) side facing you.
  3. Re-insert the battery door, and rotate clockwise until secure.
Please note, Wahoo does not recommend the use of any battery with a "bitter/child deterrent" coating (specifically, but not limited to those made by Duracell). These batteries are not approved for use Wahoo devices and may only be used at your own risk should you choose to use them. This coating has the potential to reduce battery performance and may temporarily degrade sensor functionality. Wahoo recommends using Panasonic coin-cell batteries or another name brand for optimal performance and tracking.
