KICKR MOVE (2023) Firmware Release Notes
This page contains firmware update notes for the KICKR MOVE which features fore-aft movement, Wi-Fi, and  AXIS feet for improved compliance.
KICKR MOVE Firmware v1.5.24 - 20 November, 2024
  • Updated: Optimizations and stability improvements
KICKR MOVE Firmware v1.4.37 - 28 October, 2024
  • Updated: Zwift protocol version.
  • Fixed: Virtual shifting would not disable when Zwift disconnects.
  • Fixed: Auto-spindown errors when using virtual shifting in specific scenarios.
    • In the previous firmware versions, there was an issue with the trainer calculating the correct spindown values during the auto calibration process in certain scenarios when also using Zwift Virtual Shifting. The conditions could result in the trainer reporting "ghost" watts (watts while coasting), and could result in a power offset throughout the ride. If you are currently experiencing "ghost" watts, this firmware update will not immediately fix the issue on its own, but having updated to the current firmware, the auto calibration process will fix the power offset over time without manual intervention. If you would like to resolve the power offset immediately, you can complete a factory spindown.
KICKR MOVE Firmware v1.4.5 - 29 April, 2024
  • Fixed: 2000 watt power spike when switching between ERG/SIM
KICKR MOVE Firmware v1.3.14 - 22 February, 2024
KICKR MOVE Firmware v1.1.2 / Wi-Fi 1.0.14 - 12 September, 2023
  • Added: Vertical offset for KICKR CLIMB + CLIMB base adapter
KICKR MOVE Firmware v1.0.13 / Wi-Fi 1.0.14 - 12 September, 2023
  • Initial release -- out of box
