Bicycle Frame Compatibility [KICKR MOVE]
This article addresses bicycle frame compatibility for KICKR MOVE smart bike trainers. Please also review the article on Drivetrain Compatibility for KICKR, CORE, and MOVE trainers.
Because of the wide variety of bicycle makes and models, it is not possible for Wahoo to guarantee the KICKR’s compatibility with all bicycles matching these parameters. To fully ensure compatibility, we recommend visiting a local Wahoo retailer to test your bicycle’s fit before purchasing.
Please take note of the Known Bike Incompatibilities listed below.  While Wahoo has conducted tests on KICKR safety and compatibility with certain bikes, the KICKR end user is ultimately responsible for ensuring that their bike frame is compatible with the KICKR trainers such that damage to the bike frame does not result from using the KICKR trainer.
Before riding for the first time, we suggest gently mounting the bike frame and confirming that the bike is secure, squarely in contact with the mounting points, does not exhibit excess movement, and that no part of the bicycle frame contacts the frame or moving parts of the trainer except at the designed contact points.  If no concern is found, we suggest paying attention for abnormal movement or sound during the first ride.  If found, stop riding and contact our support team to review the installation.
Wahoo Fitness strongly discourages altering trainers to fit bikes that deviate from the following specifications including (but not limited to) grinding-down components, adding washers, or improperly reversing spacers as these may void your warranty and increase inherent risk. Wahoo Fitness is not liable for any damage or injury related to improper installation, modification, or misuse of hardware.
1. Supported Wheel Sizes
Wheel Size ISO Description
650B / 27.5 inch 584 mm gravel, mountain
700C 622 mm road, cross gravel, hybrid
29 inch 622 mm mountain
Any size not listed in the above table is not compatible.
2. Supported Rear Hub Standards
Type Standard Description Uses Also Requires
Quick Release 10x130mm Common road
  • Adapter A
  • Adapter B
QR axle, included
  10x135mm Hybrid, legacy mountain
  • Adapter A
  • Adapter B
QR axle, included
Thru Axle 12x142mm Common road, cross, gravel, standard mountain
  • Adapter C
  • Adapter D
Your bike's thru axle
  12x148mm Boost mountain
  • Adapter C
  • Adapter E
If not found in the list above, your bike is not compatible. Specifically the following hub standards and bike types are incompatible:
3. Unsupported Rear Hub Standards/Bike Concepts
Quick Release 10x120mm Track
  10x126mm Legacy road, < 8 speed
  10x141mm Boost QR
Thru Axle 12x135mm Legacy Specialized SCS
  12x157mm SuperBoost mountain
4. Known Bike Incompatibilities
The following bikes are not compatible with KICKR MOVE.
  • Bianchi Aria Disc: 2021-22
    Bianchi Infinito CV Disc: 2021-22
    Bianchi Oltre XR3 Disc: 2021-22
    Bianchi Oltre XR4 Disc: 2021-22
  • Canyon Ultimate with rim brakes [The disc brake version is compatible.]
  • Rose Reveal Plus [or any bike using the Mahle X20 rear hub drive interface].
  • Specialized Crux Expert Evo: 2015
  • Trek Domane+ ALR-5: 2023-2025 [or any bike using the Trek 141 QR/bolt on standard]
5. Conditional compatibilities
The following bikes are compatible only when the following conditions are met:
  • Electric Bikes (eBikes) can be used on a KICKR or CORE when:
    • The bike uses one of the supported rear hub mounting standards described above in 2.
    • The motor is off and not providing any assistance.
    • The combined weight of rider, bike, and battery is below the stated limit of 250lbs / 113 kg.
    • The manufacturer has confirmed no concerns regarding the bike’s integrity when used on a stationary trainer.
