The serial number of a Wahoo product is generally an 11 digit numerical code. (Some older legacy products may contain letters and be 12 characters.).
For larger products like BIKEs, smart trainers, and trainer accessories, the serial number will be located toward the bottom of a white sticker, generally with the label Serial or S/N.
For computers, watch, and pedals, it will be laser etched into the product itself.
KICKR RUN
On the left front panel, opposite the power plug
KICKR BIKE
On the back of the center mast, below the crank.
BIKE SHIFT
On the inside of the left rear leg, most easily seen from the right.
KICKR wheel-off trainers (KICKR, MOVE, and CORE)
On the drive side (right side as you are riding the trainer) of the flywheel plastic cover.
SNAP
On the drive side (right side as you are riding the trainer) of the roller unit.
ROLLR
On the bottom of the unit.
CLIMB
HEADWIND
ELEMNT Computers (ELEMNT, BOLT, ROAM, and MINI)
ACE, BOLT, and ROAM -- Laser etched on the back of the unit, above the mount point.
ELEMNT and MINI -- On a white sticker in a recessed space on the back of the unit, below the mount.
RIVAL
Laser etched in the left side of the back of the unit.
TRACKR RADAR
Laser etched below and to the right of the mount point on the back of the unit.
SPEEDPLAY POWER pedals
Laser etched into the power pod, facing the pedal body of each pedal.
Speedplay Zero, Nano, and Comp
Laser etched on the the rear spine of each pedal body.
Speedplay Aero
Laser etched into to top front edge of each pedal body.
Unserialized products.
The following products do not have serial numbers.
- TRACKR HEART RATE (4 digit date code, back side, upper right corner)
- TICKR (4 digit date code, back side, upper right corner)
- TICKR X (4 digit date code, back side, upper right corner)
- TICKR Fit
- TRACKR Speed
- RPM Speed
- RPM Cadence
- Blue SC
- Desk
