KICKR is stuck or locking up
This article applies to KICKR, MOVE, CORE, and SNAP trainers. Links on this page will open into new tabs to ensure you do not lose your place in the troubleshooting flow.
1. Target Power (ERG) mode explained
Target power (ERG) mode allows you, the rider, to maintain a consistent power output during indoor training. Instead of adjusting resistance based on speed or virtual terrain, ERG mode sets a target power level, and the trainer automatically adjusts resistance to keep you at that wattage. This feature enables precise and structured workouts, making it ideal for interval training or following specific power-based training plans. ERG mode allows you to focus on hitting your power targets without worrying about adjusting resistance manually.
If you slow down your pedaling, the trainer will increase resistance to reach the target wattage in the workout. If the target is not met, the resistance can increase to an impossible level. If this happens, it can be resolved by coasting for a few seconds; then, the resistance will release, allowing you to resume your interval.
For more information on trainer control modes in the Wahoo app, see Trainer control modes for KICKR, CORE, SNAP, or BIKE in the Wahoo app.
If that's not the issue, or you're not using ERG mode...
2. Close all apps and reopen only target app.
Multi-peripheral Bluetooth capable trainers can connect to up to 3 devices at once. While this means that you can connect the trainer to more than app or device over Bluetooth at a time, only one app or device should control the trainer at a time.
  1. Close all apps on your phone or tablet, and power down and ideally unplug all other wireless devices capable of communicating with the trainer in your space.
  2. Then re-open only the app you wish to use to control the trainer.
3. Reset (power cycle) trainer
Sometimes the trainer may get stuck with a previous connection that you have closed. In this instance, you should hard reset the trainer.
Wahoo trainers do not have a power button. To reset the trainer's control chip, unplug it for 30-35 seconds.
It can be a good idea to restart the desired controlling app again during this reset period.
4. Connect the trainer to the Wahoo app
If you have been trying to connect to a different app, try connecting the trainer to the Wahoo app.
If the app you were trying to pair to initially was the Wahoo app, skip this step.
5. Check for a firmware update, and if available, update.
See Firmware update process + troubleshooting
Once updated, or if already updated:
  1.  Force close the Wahoo app
  2. With the Wahoo app closed, unplug the trainer for 30-35 seconds
  3. Plug the trainer back in, and re-open your preferred app.
6. Complete a factory spindown
See Factory spindown KICKR/MOVE/CORE/SNAP
If your concern is unresolved or you have questions, please submit a support request and our support team will be happy to assist you further.
