Using ANT+ Rear View Radar Sensors with [ELEMNT]
ELEMNT, BOLT, and ROAM can pair with rear view radar systems (like the Wahoo TRACKR RADAR, Garmin Varia, or Trek Carback) following the same pairing procedure as any other Bluetooth or ANT+ sensor.
For information on using radar units with ELEMNT ACE, see Use ANT+ Rear View Radar sensors with ELEMNT ACE.
Requirements
  • ELEMNT, BOLT, or ROAM updated to current firmware.
  • ROAM v2 or BOLT v2 to control light modes.
  • If using the first generation Garmin Varia, it must be also be updated to the newest firmware.
Radar Settings On ELEMNT computers
Once your ANT+ radar is paired, additional settings (including mute) may be accessed by opening the settings menu with the left side button and selecting MORE while the sensor is highlighted on the list. Toggle between the options below by pressing the right button with ALERT MODE highlighted.
r2-sensors-radarselected-r300.png r2-radardetails1-r300.png r2-radardetails2-r300.png
Battery level
  • Good - battery > 20%
  • Low - batter < 20%
Alert mode
  • ON - Radar and visual and audio alerts are ON.
  • MUTE - Radar and visual alerts (radar lane) are ON, but audio alerts are muted / OFF.
  • OFF - Radar function is turned off, removing visual alerts (radar lane) and audio alerts OFF.
Light Mode
(requires second generation computer, ROAM v2 or BOLT v2)
Dependent upon the radar's available preset light settings.
Auto light
If enabled, (and the radar has a tail light) the light will flash asymmetrically when a car is approaching, and continue to do so for the period of time selected (1, 5, or 10 seconds) and then return to the selected light mode variety.  If disabled, the currently selected light mode will perform as defined by the light mode.
  • OFF - Light performs as selected
  • 1S - Light flashes as car is approaching + 1 second
  • 5S - Light flashes as car is approaching + 5 seconds
  • 10S - Light flashes as car is approaching + 10 seconds
Radar Settings in the ELEMNT app
To edit radar settings in the ELEMNT app, go to the Settings tab > Set up sensors > Bike Radar > Alert Settings.
baca-sensors-radarselected-300.png baca-radar-alertsettings-300.png bacar-radar-settings-300.png
Alerts
  • OFF - Radar is on, and car lane is visible, but secondary visual alerts are removed.
Location of car representation
  • Left LEDs - uses left side LEDs on ELEMNT/ROAM as visual car lane (not available on BOLT)
  • Left on-screen - car lane on left side of screen
  • Right on-screen - car lane on right side of screen
Show radar status on top LEDs
If enabled, top LED color will change state to mark car passing statu
  • Green - All clear
  • Amber - Car passing normally
  • Red - Car passing dangerously
Radar Lane
  • LEFT - Radar lane / car track appears on the left side of display
  • RIGHT - Radar lane / car track appears on the right side of display
Sounds
Visual alerts are coupled with warning beeps or not.
Varia Radar performance specifications (as defined by Garmin)
  • The radar detects approaching vehicles up to 140m (153 yards) away.
  • The approaching vehicle speed must be from 10 to 160 km/h (from 6 to 99 mph).
  • NOTE: The radar does not detect vehicles traveling at the same speed as your bike.
  • The radar beam width is 40 degrees. It provides radar coverage for typical bends in the road.
  • The radar can detect up to eight approaching vehicles.
  • The vehicle position moves up the column as a vehicle gets closer to your bike. The threat level  changes color based on the potential level of threat.
    • Green indicates no vehicle is detected.
    • Amber indicates a vehicle is approaching.
    • Red indicates a vehicle is advancing at a high rate of speed.
      • A fast vehicle is detected (any vehicle faster than 90km/h (55mph) relative to the bike or any vehicle significantly faster than the average vehicle speed).
      • A slow-moving cyclist is being tracked behind you and a new vehicle is detected in the distance.
For further questions/concerns regarding Varia performance, please contact Garmin Support.
For further questions/concerns regarding CarBack performance, please contact Trek Support.
