Customize workout profiles and pages in the Wahoo app
The Wahoo app uses Workout Profiles (collections of data pages and settings) that are preset for use with a given activity type, ex. Cycling, Running, Indoor Cycling, or Lap Swimming.  Each activity has its own set of data pages with preset data fields that correspond to the activity being recorded.
With version 6.69 or newer, the Wahoo app will allow you to
  1. customize (add, remove, reorder) the data pages that appear when recording an activity in the app for most workout profiles and to
  2. customize most of the data fields on each workout page of a workout profile.
This mirrors the experience of customizing workout profiles and pages for our Gen3 ELEMNT computers (ACE, BOLT v3, ROAM v3).  If you are an ELEMNT user, the changes you make to any given workout profile will be reflected on both your computer and in the Wahoo app's activity recorder.  If you use both but wish to have a different experience between the two, we suggest creating duplicate workout profiles, and then renaming and customizing one.  For more details on duplicating a workout profile, see Workout Profiles [Wahoo app].
You can access the list of workout profiles by selecting the Account icon at the top left corner of the Today tab, and then selecting the Workout profiles button on the Account page.
wa-today-home-accountselected-300.png wa-account-workoutprofilesselected-300.png wa-workoutprofiles-300.png
Customize a Workout profile's pages
You can add pages, toggle off default pages, and change the order in which pages appear for both the default workout profiles and custom ones that you create. To do so:
  1. Select the workout profile that you would like to customize.
  2. Select the Workout pages button
  3. Use the three dots ( ... ) in the top right corner to open the Edit menu and select Add page to add a page, OR
  4. Use the toggle to the left of a page to toggle off that page in the activity recorder. Pages labeled with ELEMNT will not appear in the activity recorder. OR
  5. Long press a page until it enlarges to move it up or down in the page view order. OR
  6. Select the > icon next to a page to customize that page's data fields
Customize a workout page's data fields
In addition to customizing what pages appear (and in what order they appear) in the activity recorder, you can also customize what data fields appear on each page and in what order they appear. To customize a specific page's data fields:
  1. Select the desired workout page, ex. Workout data.
  2. Scroll to the bottom of the page and select the (+) (add) icon to add a field, OR
    • This icon will not be available if the maximum
  3. Select the (-) icon to the left of a field to delete it OR
  4. Long press a field until it expands to change its location on the page OR
  5. Select the > icon to the right of a field to replace it with another field. Navigate in the menus that follow to locate your desired field and select it.
Reset a page's data fields to default settings
If you decide you do not like your customized configuration and want to restart from scratch, you can reset a given workout page to its defaults
  1. Select the  ...  (3 dots) at the top of the page and then select Reset to default.
  2. Confirm the page reset by selecting Reset.
  3. Tap the 3 dots at the top of the Workout Profile All Workout pages to set them all back to default
  4. Tap the 3 dots at the top of the Workout Profile page to revert all settings and pages for the workout profile back to default
Reset all pages to default settings
If you want to reset all of a workout profile's pages to their default data fields,
  1. Navigate to the workout profile, and then to the Workout pages page.
  2. Select the ... three dots in the top right corner and then Reset to default.
  3. Confirm the reset of all pages by selecting Reset.
Reset all of a workout profile to default settings
In order to reset all aspects (page configurations and settings) of a workout profile to the default settings for the workout profile type from which it was created,
  1. Navigate to the workout profile.
  3. Confirm the reset by selecting Reset to default.
Remember that if you have a computer paired, changes to any profile affects that profile for both the computer and the app activity recorder.
