KICKR ROLLR Product Information & FAQ
The Wahoo KICKR ROLLR is designed to easily transfer your bike between the road and a home training studio. Thanks to an adjustable wheelbase and front tire gripper stabilizer arm, Wahooligans can set up almost any bike without removing wheels or installing additional adapters. Designed with convenience and ease of use in mind, KICKR ROLLR offers a seamless transition between indoor and outdoor riding as well as access to virtual cycling worlds like Zwift, structured workouts in SYSTM or the Wahoo app, and other virtual training programs.
Download the Wahoo App
The Wahoo Fitness app keeps your trainer up to date and leverages your smartphone to record basic workout information, delivering data-driven power that fuels your training and fitness goals. Get the app now to register your KICKR and get cranking.
KICKR ROLLR Design Specifications
  • Part Number: WFBKTR9B
  • Dimensions: 31.25" x 34" x 57.5-65" (79.5 x 86.5 x 146-165 cm)
  • Weight: 50 lbs (22.6 kg) Unboxed
  • KICKR CLIMB Compatible: No
  • KICKR HEADWIND Compatible: Yes
  • Accuracy: Determined by external power meter (on-bike) or consistent use with the same bicycle (onboard)
  • Wireless Software Updates: Yes (Wahoo App)
  • Connectivity: Bluetooth® FTMS, ANT+ FE-C, Direct Connect
  • Max User Weight: 250 lb
  • Flywheel Weight: 10.5 lb
  • Maximum Power Output: 1500W
  • Maximum Simulated Grade: 10%
  • Minimum Simulated Grade: -10%'
In The Box
  1. KICKR ROLLR rear assembly (rear ROLLR body)
  2. KICKR ROLLR front assembly (front base)
  3. KICKR ROLLR middle leg
  4. Support arms
  5. Tire gripper assembly
  6. AC power adapter
  7. Large Allen bolts (x4)
  8. Small Allen bolts (x6)
  9. 5mm Allen key with Phillips head
  10. 4mm Allen key
*Caution: Use of third party power adapters not supplied by Wahoo Fitness may cause permanent damage to your trainer.
The KICKR ROLLR can be used with or without a power meter to deliver consistent training data. The onboard power of KICKR ROLLR provides consistent power readings during steady-state riding, enabling users to follow structured workouts and track their progress consistently from session to session. While the power accuracy may not match direct-drive trainers due to the free-moving rear end of the bicycle, it delivers dependable performance for riders less concerned with precision and more focused on their fitness journey.
For those seeking enhanced accuracy, Wahoo’s Power Meter Connect feature allows users to pair the KICKR ROLLR with third-party power meters, ensuring precise power data for interactive workouts or virtual racing. This flexibility makes the KICKR ROLLR adaptable to a wide range of training needs.
Compatibility
