Ready to Ride dashboard in Wahoo App for ELEMNT ACE, ROAM 3 and BOLT 3
When opening the Wahoo app with an ELEMNT device connected, the Ready to Ride dashboard will display on the immediate homepage. From here, you can manage your workout profile, route, and structured workout selections, and check the connection, battery, and data status of any paired sensors, with any changes made in the Wahoo app reflected on your bike computer.
The Ready to Ride dashboard will display all paired bike computers on the home screen. An actively connected bike computer will display at the top of the list. If more than one are connected, it will order by the most recently connected.
The dashboard can be accessed via the 'Set up ride' button. During an active ride, the distance, duration and elevation gain will be presented on the Ready to Ride dashboard.
Workout profiles
Once in the Ready to Ride dashboard, the workout profile can be selected by swiping across on the screen, so that you can quickly toggle between your customized profiles for training, racing, commuting, MTB, etc. Workout pages on each workout profile can be adjusted, along with the settings for each workout profile.
Add route
Below the workout profile options, a route can be selected using the 'Add route' option. This will display all synced routes, along with the following information for each route:
  • Route name
  • Distance
  • Total elevation gain
  • Route provider / origin
  • Route map preview
Selecting on a route option will provide a more comprehensive preview of the route, including the elevation profile, maximum and minimum gradient and an interactive map with the route overlayed.
Clicking 'Select route' will confirm the route in the Ready to Ride dashboard and sync it across to the connected bike computer.
The selected route can also be changed or ended while on the Ready to Ride dashboard.
Add workout
Below the Add route button is an Add workout button to access any planned structured workouts that have been synced to the ELEMNT device via Wi-Fi or manually synced via Bluetooth from the Wahoo app.
Synced planned workouts can be selected, along with a selection of SYSTM workouts in the 'Explore workouts' tab.
Once a workout is selected, workout details can be viewed, and the workout can be changed or removed.
Sensors
Connected sensors can be viewed under the Sensors tab, displaying the battery level of each sensor as a fuel gauge. Any paired sensors that are not actively connected to the ELEMNT device will not appear in the Ready to Ride dashboard.
Sensors cannot be paired or forgotten through the Ready to Ride dashboard, and must be managed on the ELEMNT device directly. For more information, please see Pair an ELEMNT ACE, ROAM 3 or BOLT 3.
