Connect an ELEMNT ACE, BOLT 3, or ROAM 3 to Wi-Fi
The following article describes the Wi-Fi experience with Gen 3 ELEMNT GPS computers (ACE, BOLT 3, or ROAM 3).  For information about using Wi-Fi with ELEMNT, BOLT 1/2, or ROAM 1/2, see Connect an ELEMNT computer to Wi-Fi
ELEMNT GPS computers require a direct ELEMNT computer > Wi-Fi connection for firmware updates, route or map downloads, completed activity auto-upload, Strava Live Segment synchronization, and other internet-enabled features. If you're having trouble with an internet-based feature, it's a good idea to ensure the connection is still active following the steps below.
Requirements
  • the ELEMNT ACE, ROAM 3, or BOLT 3  is paired to the Wahoo app on your phone/tablet
  • there is a Wi-Fi network within range of the computer that is
    • 2.4 or 5 Ghz frequency,
    • set to a channel, 1-9,
    • authenticated via simple text password, not a secondary splash page, and
    • does not have MAC address filtering/whitelisting enabled.
      • In order to support privacy/safety, ELEMNT computers produce randomized MAC addresses upon restart.
How to connect
  1. With the ELEMNT computer actively paired to the Wahoo app, in the Wahoo app, navigate to the Devices tab.
  2. Scroll down to Wi-Fi and select WiFi Network.
  3. Select the your Wi-Fi network from the list that appears.
  4. Enter the password when prompted and select Join.
wa-mydevices-ace-300.png wa-devices-ace-devicedetails-settingsselected-300.png wa-acesettings-wifiselected-300.png
wa-wifi-selectnetwork-300.png wa-wifi-enterpassword-300.png blank300x200.png
Connected networks are saved on the ELEMNT and will automatically reconnect when in range, regardless of the computer's pairing status with the Wahoo app.
  • If a network is saved and connected, it will appear immediately below the ELEMNT Wi-Fi toggle with a check mark beside it.
  • If a network is saved, but not connected, it will appear just below the ELEMNT Wi-Fi toggle, but without a check mark.
  • Networks that are in range, but neither saved, nor connected will appear below OTHER NETWORKS.
Using ELEMNT Wi-Fi
Wi-Fi is used primarily to update computer firmware, download maps, and bulk sync third party route libraries, planned workouts, and Strava Live Segments.
Once a single (or multiple) Wi-Fi network is saved to an ELEMNT ACE computer, as the ELEMNT computer is warming up, it will check for an available saved network. If a saved network is found, the computer will check the computer's records against a Wahoo cloud server for:
  • current firmware
  • updated routes
  • planned workouts
  • Strava Live Segments (if enabled)
If found, updated records will be synced (downloaded to the computer).
A Wi-Fi sync event can also be manually triggered by prompting the computer to check for a firmware update, or sync routes, planned workouts, or Strava Live Segments.  Triggering a sync event for one will sync any/all of the above components.
After the warmup period as a computer starts up, or if a sync event has been triggered, a Wi-Fi icon will appear in the status bar at the top of the computer screen (with time, temperature, phone connection status, battery level, etc).  The Wi-Fi icon will flash at ~ 1 second intervals while the computer attempts a connection.  If a connection is successful, the icon will become solid.
If the computer is not connected during warm up, shut down, or a connection has not been manually triggered, the computers will shut off the Wi-Fi connection to save power.
Troubleshooting Wi-Fi issues
If you are unable to get your ELEMNT to connect to a particular Wi-Fi network, review the following:
  • ELEMNT computers only connect to WiFi channels 1 - 9. Though most Wi-Fi routers will auto-select a channel from 1 - 9, on some routers, particularly those in the UK and EU, it's possible for the channel to be set outside this range manually. Please check your router settings following manufacturer instructions.
  • ELEMNT computers do not support networks that require a splash page to connect (802.1x EAP networks). These are often found in hotels, restaurants, and airports which send devices to a web page for authentication or acceptance of terms before granting internet access.
  • ELEMNT computers are incompatible with networks that use MAC address filters or whitelists, as they use dynamic, randomized MAC addresses for privacy and security purposes as prescribed in Android documentation.
  • ELEMNT computers can connect mobile hotspots. In some cases, a second phone (not the one running the Wahoo app) may be required to provide the Wi-Fi hotspot connection.
If you have confirmed that the Wi-Fi network meets all of the compatibility criteria above and you still cannot connect:
  • Restart the computer, your phone, and the router (if available), and then try again.
  • Try connecting to a mobile hotspot on a second phone.  Some phones struggle with managing the Bluetooth and Wi-Fi connection to the ELEMNT simultaneously.
  • Try another Wi-Fi network entirely.  The great majority of issues are caused by current network settings, or an incompatible or insufficiently resourced Wi-Fi network. We have not seen a case of a computer's Wi-Fi connectivity failing without other connections failing as well.
