Pair to Wahoo app KICKR/MOVE/CORE [tsg]
Pair to Wahoo app
If the app you were trying to pair to initially was the Wahoo app, skip this step.
Pair a sensor
1. Open the Wahoo app.
2. Open the Devices tab.
3. Select Pair sensor (or the + sign if another sensor is paired).
4. Select the desired sensor.
5. The sensor is paired.
Select a sensor as a data source
A newly paired sensor will show as Connected and be set as a data source for any of the data types for which it could be selected.
You can change the data source for a given data type by tapping a data source panel at the top of the drawer and selecting a compatible sensor from the list that appears. Alternately, you can de-select a data type at the bottom of a sensor panel in the My sensors list and select that data type under another sensor.
Data source selections for a given workout profile will persist until they are changed.
