Use a KICKR ROLLR with onboard power
Following firmware update 1.1.31, the Wahoo KICKR ROLLR supports power and resistance changes with a onboard power setting. This setting is meant for personal training and entertainment purposes, and will not be comparable to other sources equipped with a power meter.
Power values will be consistent from ride to ride if:
  • The same bicycle is repeatedly used with the KICKR ROLLR
  • Tire pressure remains consistent
  • You pump up your rear tire to a specific PSI before every ride
For athletes requiring precision power values for racing and training with multiple devices, the KICKR ROLLR offers enhanced power accuracy through the On-Bike power feature, which utilizes power from an external power meter (SPEEDPLAY POWER pedals or another ANT+ power meter to transmit power and cadence data to a controlling app or device). For more information, see Pair a power meter to KICKR ROLLR (On-bike power).
Note: Due to the accuracy limitations of Onboard power, the acceptability of using virtual power in racing in the app is at the discretion of a given event's race directors.
Requirements
Pairing Instructions
  1. Pair your KICKR ROLLR to the Wahoo app for iOS or Android like any other sensor, smart trainer, or smart bike.
  2. Once paired, select the ROLLR from the My sensors list in the Devices tab.
  3. Select Update now to update your ROLLR firmware.
    wa-rollr-details-firmwareupdate - 300px.png wa-rollr-firmwareupdating-300.png wa-rollrfirmwareupdated-300.png
  4. Under Power meter source select Onboard. This is the default setting with the KICKR ROLLR.
  5. Connect your KICKR ROLLR to your desired app when prompted to pair.
Note: The KICKR ROLLR does not provide cadence data.
