Sync / download third party routes to ELEMNT computers
You can create a route to sync to your ELEMNT using RideWithGPS, Komoot*, Strava, or TrailForks. Routes can be synced to the computer either over WiFi or Bluetooth.
Notes:
*As of February 27, 2025, syncing komoot routes to Wahoo ELEMNT computers will require a komoot Premium subscription for all new users. However, existing users who have purchased the World Pack or other unlocked map products before this date will continue to be able to sync tours in regions which they had previously purchased as before.  To confirm what regions you have purchased, see komoot.com/account/regions.
If using an ELEMNT or BOLT v1, you will only get Turn by Turn notifications for routes created in RideWithGPS and Komoot. Strava and Trail Forks routing software does not produce cues for Turn by Turn.
Compatibility
  • All ELEMNT GPS Bike Computers
Requirements
Sync / Download your 3rd party app route library over WiFi
1. Connect the ELEMNT to Wi-Fi
  1. With the ELEMNT on, open the ELEMNT app.
  2. On the Settings tab of the ELEMNT app select WiFi Network.
  3. Select your network and enter the password to authenticate the ELEMNT.
For additional help, see Connect ELEMNT to Wi-Fi.
2. Link your 3rd party account to your Wahoo account
In the ELEMNT app:
  1. Select the Profile tab, then Authorized apps.
  2. Select the 3rd party routing app your wish to sync routes from (ex RideWithGPS, Komoot, Strava, or Trailforks)
  3. Enter your username / password or authenticate your account with the 3rd party app as prompted
3. Sync your 3rd party account route library
  • Komoot: All planned tours
  • RideWithGPS: All pinned routes + routes you have created
  • Strava: All starred routes + routes you have created
  • Trailforks: Routes, Rideplans (user-created routes), and Ridelogs as found in the "My Wishlist Routes" tab of the Trailforks mobile app.
On the ELEMNT itself,
  1. Navigate to the Map page.
  2. Select Routes (three dots [...] if using BOLT v2 or ROAM v2, then Routes)
  3. Select SYNC to begin syncing the route libraries of whatever 3rd party services you have linked in step 2.
Your route library will then load onto the Routes page of the ELEMNT.  You can sort them by name, proximity, and other. If set to Proximity, and your ELEMNT does not have a GPS lock, no routes will be shown.
Sync a single route over Bluetooth
In the ELEMNT app:
Sync a single route from the ELEMNT app via Bluetooth
With your ELEMNT connected to the ELEMNT App, in the ELEMNT app:
  1. Select the Workout tab.
  2. Select Choose a route
  3. Select your desired route.
  4. Select Select route.
A status screen should appear with 'Route loading'.  'Route loaded' will appear on the ELEMNT screen.
Live Chat support is currently unavailable while our HELPR Bot is under construction.
