KICKR v1-5, CORE, and SNAP LEDs
Red LED:
- Always on (indicates power)
- Flashes quickly when ANT command/data is received
Blue LED:
- Blinks once per second when disconnected and advertising Bluetooth
- Solid when connected via Bluetooth, blinks quickly during information transfers
- Flashes quickly when connecting to a device via Bluetooth
Auto LED Sleep:
As of October 13, 2021, fully updated KICKR v4 (2018) + , CORE, and MOVE LEDs will turn off after 15 minutes of inactivity. Flywheel movement or activating a Bluetooth connection will re-activate LEDs.
KICKR v6 and MOVE Wi-Fi LEDs
- What is it? A white LED that indicates the WiFi connectivity status of the trainer.
- Why is it needed? Similar to Bluetooth LED, it helps the user quickly understand the connection status of the trainer.
How does it work? The led will slow blink white when searching for a network. Fast blink means it’s discovered the network and working to connect. Solid white means the trainer has a good connection to the network.
CORE 2 LEDs
The CORE 2 has two sets of LED lights to provide more information on the trainer's status to users.
Connection Status (upper LEDs)
Connection |
Light Color / Pattern |
No Connection |
Off |
Single Bluetooth |
1x blue pulse + off , breathing cycle |
Dual Bluetooth |
2x blue pulse + off breathing cycle |
Triple Bluetooth |
3x blue pulse + off breathing cycle |
Single WiFi Connection |
1x white pulse + off breathing cycle |
Bluetooth + WiFi |
1x blue pulse + 1x white pulse + off breathing cycle |
Dual Bluetooth + WiFi |
2x blue pulse + 1x white pulse + off breathing cycle |
ANT+ |
Red blinks whenever ANT+ control received |
Ready to Ride Status (lower LEDs)
State |
Color / Pattern |
Boot (turning on the trainer) |
Yellow (quick flash) |
Idle |
Green (solid) |
Powered on, flywheel turning |
White (solid) |
Undefined error |
Red (blinking) |
Zwift paired |
Orange (solid) |
Zwift Virtual Shifting enabled |
Purple (solid) |
During a Firmware Update
These lights will occur on both the upper and lower LEDs when a firmware update is needed.
State |
Color / Pattern |
Boot |
Yellow (quick flash, lower only) |
Downloading |
Yellow (upper and lower pulsing together) |
Error while downloading |
Yellow + Alternating (upper and lower alternating pulses) |
Validating |
Purple (solid, upper only) |
For more information, see this article.
