Wahoo smart trainer LEDs (KICKR, MOVE, CORE 1, CORE 2, ROLLR and SNAP)
KICKR v1-5, CORE, and SNAP LEDs
Red LED:
  • Always on (indicates power)
  • Flashes quickly when ANT command/data is received
Blue LED:
  • Blinks once per second when disconnected and advertising Bluetooth
  • Solid when connected via Bluetooth, blinks quickly during information transfers
  • Flashes quickly when connecting to a device via Bluetooth
Auto LED Sleep:
As of October 13, 2021, fully updated KICKR v4 (2018) + , CORE, and MOVE LEDs will turn off after 15 minutes of inactivity. Flywheel movement or activating a Bluetooth connection will re-activate LEDs.
KICKR ROLLR LEDs
Red LED indicates whether a power meter is connected to the ROLLR:
  • Solid Red - Connected to power meter
  • Flashing Slow Red - Searching for an unknown power meter
  • Flashing Fast Red - Searching for a known power meter
Blue LED indicates the status of the ROLLR's Bluetooth connection:
KICKR v6 and MOVE Wi-Fi LEDs
  • What is it? A white LED that indicates the WiFi connectivity status of the trainer.
  • Why is it needed? Similar to Bluetooth LED, it helps the user quickly understand the connection status of the trainer.
  • How does it work? The led will slow blink white when searching for a network. Fast blink means it’s discovered the network and working to connect. Solid white means the trainer has a good connection to the network.
CORE 2 LEDs
The CORE 2 has two sets of LED lights to provide more information on the trainer's status to users.
Connection Status (upper LEDs)
Connection
Light Color / Pattern
No Connection
Off
Single Bluetooth
1x blue pulse + off , breathing cycle
Dual Bluetooth
2x blue pulse + off breathing cycle
Triple Bluetooth
3x blue pulse + off breathing cycle
Single WiFi Connection
1x white pulse + off breathing cycle
Bluetooth + WiFi
1x blue pulse + 1x white pulse + off breathing cycle
Dual Bluetooth + WiFi
2x blue pulse + 1x white pulse + off breathing cycle
ANT+
Red blinks whenever ANT+ control received
Ready to Ride Status (lower LEDs)
State
Color / Pattern
Boot (turning on the trainer)
Yellow (quick flash)
Idle
Green (solid)
Powered on, flywheel turning
White (solid)
Undefined error
Red (blinking)
Zwift paired
Orange (solid)
Zwift Virtual Shifting enabled
Purple (solid)
During a Firmware Update
These lights will occur on both the upper and lower LEDs when a firmware update is needed.
State
Color / Pattern
Boot
 Yellow (quick flash, lower only)
Downloading
Yellow (upper and lower pulsing together)
Error while downloading
Yellow + Alternating (upper and lower alternating pulses)
Validating
Purple (solid, upper only)
For more information, see this article.
