What do the KICKR, CORE, and SNAP LEDs Mean?
Original LEDs
KICKR v5 (and older), KICKR CORE, and KICKR SNAP LED indicator lights function as described below:
Red LED:
  • Always on (indicates power)
  • Flashes quickly when ANT command/data is received
Blue LED:
  • Blinks once per second when disconnected and advertising Bluetooth
  • Solid when connected via Bluetooth, blinks quickly during information transfers
  • Flashes quickly when connecting to a device via Bluetooth
Auto LED Sleep: As of October 13, 2021, all fully updated KICKR's LEDs will turn off after 15 minutes of inactivity. Flywheel movement or activating a Bluetooth connection will re-activate LEDs.
New KICKR v6+ Wi-Fi LED
  • What is it? A white LED that indicates the WiFi connectivity status of the trainer.
  • Why is it needed? Similar to Bluetooth LED, it helps the user quickly understand the connection status of the trainer.
  • How does it work? The led will slow blink white when searching for a network. Fast blink means it’s discovered the network and working to connect. Solid white means the trainer has a good connection to the network.
