Add, update, or delete Maps on ELEMNT ACE, BOLT 3, or ROAM 3
ELEMNT ACE and ROAM 3 ship with all world maps, complete with all map layers, and 5+ GB of storage space remaining for routes, completed ride data, etc.  There is no reason to delete any map regions.
Because the BOLT 3 has only 32GB of storage, compared to ACE and ROAM 3's 64GB, but BOLT 3 also supports many of the same on-board routing functions, all Summit features, and robust color maps, it ships with most, but not all, of the world's maps loaded on the device.
Because map layers contain rich navigation and elevation data, even small regions are relatively large files, and so both the deletion and download processes can take some.  There is no particular value in minimizing map data or maintaining more than a gigabyte of free space, and so we suggest only deleting the regions you need to in order to make space to replace them.
If you are compelled to keep only minimal maps on the computer, turn off the Auto-off, connect the computer to a power source, and expect to leave the computer powered on for several hours.
Requirements
  • A mobile device running the current version of the Wahoo app for iOS or Android with an active data (internet) connection.
  • The ELEMNT ACE, BOLT 3, or ROAM 3 computer paired and actively connected with Wahoo app on the mobile device.
  • The ELEMNT computer itself actively connected to a local saved Wi-Fi network
From the Devices > your computer > Settings > Manage maps of the Wahoo app you can add, update, or delete maps from different regions:
  1. Open the Wahoo app on your mobile device.
  2. Select the Devices tab.
  3. Select your ELEMNT ACE.
  4. Select Settings.
  5. Scroll down to Manage maps in the Navigation section.
  6. From here you can delete, download, or update maps on your ELEMNT ACE.
wa-mydevices-ace-300.png wa-devices-ace-devicedetails-settingsselected-300.png wa-ace-devicesettings-managemapsselected-300.png
wa-ace-managemaps-300.png wa-ace-managemaps-edit.png wa-ace-managemaps-delete-300.png
Add maps
  • Select Add map and then the region you wish to add.
Update maps
  • Select the ... (three dots) in the upper right hand corner.
  • Select Update all.
Delete maps
  • Navigate to the region level from which you wish to delete the maps.
  • Select Edit.
  • Select the map region you wish to delete.
  • Select Delete.
ELEMNT ACE ships with all world maps, complete with all map layers, and 5+ GB of storage space remaining for routes, completed ride data, etc.  There is no reason to delete any map regions.
