Wahoo TICKR FIT Product Instructions
With an advanced optical sensor and an easy-to-wear armband, the rechargeable,
waterproof TICKR FIT heart rate monitor will get you cranking faster
while accelerating your workout with hard data.
Burn it up with TICKR FIT!
DOWNLOAD THE APP
Wahoo Fitness App
The Wahoo Fitness app is designed to keep your TICKR up to date and leverage your smartphone during running, cycling, or other workouts, delivering data-driven power that fuels your training and fitness goals. Get the app now to update your TICKR and get cranking.
PRODUCT INFORMATION
MAIN FEATURES
Providing accurate heart rate and calorie burn data in the most comfortable form factor yet, the TICKR FIT comes equipped with Bluetooth and ANT+ technology to seamlessly pair with fitness apps, smartphones, and GPS bike computers & watches. Worn on the forearm, the TICKR FIT comes with an adjustable band that is designed for your most grueling workouts, featuring water-resistant technology and a rechargeable battery that lasts up to 30 hours.
ULTIMATE PRECISION
TICKR FIT uses the latest in optical heart rate technology to give you accurate heart rate and calorie burn data
COMFORTABLE AND SECURE
Made from advanced performance materials, TICKR FIT is designed to comfortably fit around your arm, yet fit securely during intense activity
CONNECT WITH CONFIDENCE
TICKR Fit connects to smartphones, GPS watches and bike computers, and verifies TICKR FIT is connected by using convenient LED lights
PRODUCT SPECIFICATIONS
Rechargeable Battery: 30+ hours
Strap Length: Small 260mm x 25.4mm / Large 375mm x 25.4mm
Water Resistant: IPX7
Power Function: Physical On/Off button
DEVICE COMPATIBILITY
Apple iOS
Wahoo sensors are designed to work with the Wahoo Fitness app which supports devices running iOS 12 and newer.
ANDROID
Wahoo sensors are designed to work with the Wahoo Fitness app which supports most Bluetooth® compliant Android devices running Android version 5.1 or newer.
Note: Since Android devices vary widely, compatibility cannot be assured for all devices. Please download and install the Wahoo Fitness Android app from the Google Play Store before purchasing a Wahoo Fitness product to ensure compatibility.
WINDOWS / MAC
Wahoo sensors support various Windows and Mac applications with Bluetooth and/or ANT+ capabilities.
Note: the Wahoo Fitness app (required for important updates) is only available on iOS and Android mobile devices.
3RD PARTY APPLICATIONS
Wahoo sensors are compatible with many 3rd party iOS, Android, Windows and Mac apps. For a list of confirmed compatible 3rd party apps, see the chart at the end of this guide.
IN THE BOX
  • TICKR FIT Heart Rate Monitor
  • Small Adjustable Soft Strap
  • Large Adjustable Soft Strap
  • USB Charging Cable
  • Quick Start Guide
PRODUCT CARE
  • The TICKR FIT unit is waterproof to IPX7 specifications and easily cleaned with mild soap and water when necessary.
  • The TICKR FIT strap is hand-wash only.
SETUP
WEARING THE TICKR FIT
For greatest accuracy, the TICKR FIT works best on the upper forearm, just below the elbow on either the inside or outside of the arm. Adjust the included strap appropriate for your arm until it is comfortable, yet snug enough to remain in place during exercise.
POWERING ON AND USING LED INDICATORS
Button function
  • Long (3 sec) press: power on/off
LED Function
  • Blue LED slow blink: awake and searching (LED operation shuts off 30 seconds after waking)
  • Blue LED fast blink: connecting to device
  • Solid Blue LED: connected to device (LED operation shuts off 30 seconds after pairing)
  • Power down sequence: LED flashes red for 2 seconds, then powers off
Charging
  • If NOT full when placed on charger: green LED alternates on/off
  • When FULLY charged, LED holds solid green for 5 seconds, then powers off
Low Battery Indicator
  • LED flashes orange 3 times: battery at 15% or lower; normal LED function resumes after flashing
  • LED flashes red for 2 seconds: low battery shut off - TICKR FIT will automatically power down when the battery is too low, flashing RED for 2 seconds, then powering off. If powered on below the 5% threshold, LED will flash red again for 2 seconds, then shut down.
PAIRING WITH iOS DEVICES
The TICKR FIT follows the same pairing procedure as the KICKR, outlined below:
  1. Ensure Bluetooth® is turned on and open the Wahoo Fitness iOS App
  2. Select the Settings tab in the bottom right corner.
  3. Select the Sensors line item.
  4. Choose your TICKR from the available sensors.
  5. For the best accuracy and reliability, always keep your TICKR updated if prompted. Take a moment to enter personal measurements like height and weight as well.
  6. When complete, select "Save Sensor,” then choose the workout profiles you would like the TICKR active for (ex. Indoor Bike Trainer)
  7. Select "Done” to complete the pairing & workout selection process
Your TICKR is now paired and ready for action! To use your TICKR, start a workout in one of the profiles you marked the TICKR active for. Swipe right within a workout to access additional details and metrics.
Since the Wahoo Fitness app remembers saved devices, you can skip the sensors page next time - just start a new workout to get kickin! You can also try your sensor with one of our favorite 3rd party apps.
The TICKR FIT is also compatible with the ELEMNT and ELEMNT BOLT.
PAIRING WITH ANDROID DEVICES
The TICKR FIT follows the same pairing procedure as the KICKR, outlined in the video below:
  1. Ensure Bluetooth® and location services are turned on and open the Wahoo Fitness Android App
  6. Select “Save device” and choose the workout profiles you would like the KICKR active for (ex. Indoor Cycling)
  7. Select “Ok” to complete the pairing and workout selection process
