Tire Size > Wheel Circumference Chart
For the most accurate data from a speed sensor like the TRACKR SPEED, Wahoo RPM Speed or Blue SC, measure and input your wheel circumference in the Wahoo Fitness App. An accurate speed sensor can also improve the speed/ distance data accuracy of GPS Bike Computers, especially in tree cover or near buildings.
Manual Rollout Measurement
Because wheels of the same "size" come with rims of varying widths, tires of the same "size" will often vary in actual size and tread pattern, and inflation pressure will affect tire circumference, in order to determine most accurate circumference value of your wheel, inflate your tire to the pressure you use when riding and then complete a manual rollout measurement.
Mark a point on the floor/driveway and place your front wheel with the valve stem at the bottom of the wheel at that point. Roll the bike one wheel revolution forward in a straight line, until the valve stem is again at the bottom of the wheel. Mark that spot. Set your bike aside and measure the distance between the two points in metric units, or convert and enter that value in meters. One imperial inch = 25.4mm or .0254 meters.
Tire Size > Wheel Circumference Approximation Chart
For a near approximation of wheel circumference, you can find tire size written/molded into the side of your tires. Find that tire size in the chart below and enter the corresponding value in meters.
Please see Setting Up Wheel Circumference for detailed instructions and additional information.
Tire Size ISO
Circumference in mm
700 x 18C 18-622 2070
700 x 19C 19-622 2080
700 x 20C 20-622 2086
700 x 23C 23-622 2096
700 x 25C 25-622 2109
700 x 28C 28-622 2127
700 x 30C 30-622 2140
700 x 32C 32-622 2152
700 x 35C 35-622 2171
700 x 38C 38-622 2190
700 x 40C 40-622 2203
700 x 44C 44-622 2230
700 x 45C 45-622 2234
700 x 47C 47-622 2247
700 x 50C 50-622 2265
650 x 20C 20-571 1938
650 x 23C 23-571 1944
650 x 35A 37-590 2090
650 x 38B 40-584 2105
650 x 38A 40-590 2125
12" x 1.75" 47-203 0935
12" x 1.95" 54-203 0940
14" x 1.50" 40-254 1020
14" x 1.75" 47-254 1055
16" x 1.50" 40-305 1185
16" x 1.75" 47-305 1195
16" x 2.00" 54-305 1245
16" x 1-1/8" 28-349 1290
16" x 1-3/8" 37-349 1300
18" x 1.50" 40-355 1340
18" x 1.75" 47-355 1350
20" x 1.25" 32-406 1450
20" x 1.35" 35-406 1460
20" x 1.50" 40-406 1490
20" x 1.75" 47-406 1515
20" x 1.95" 50-406 1565
20" x 1-1/8" 28-451 1545
20" x 1-3/8" 37-451 1615
22" x 1-3/8" 37-501 1770
22" x 1-1/2" 40-501 1785
24" x 3/4" Tubular   1785
24" x 1" 25-520 1753
24" x 1-1/8" 28-540 1795
24" x 1-1/4" 32-540 1905
24" x 1.75" 47-507 1890
24" x 2.00" 50-507 1925
24" x 2.125" 54-507 1965
26" x 7/8" Tubular   1920
26" x 1.25" 32-559 1950
26" x 1.40" 37-559 2005
26" x 1.50" 40-559 2010
26" x 1.75" 47-559 2023
26" x 1.95" 50-559 2050
26" x 2.00" 52-559 2055
26" x 2.1" 54-559 2068
26" x 2.125" 57-559 2070
26" x 2.35" 58-559 2083
26" x 3.00" 75-559 2170
26" x 1-1.0" 25-559 1913
26" x 1" 25-571 1952
26" x 1-1/8" 28-590 1970
26" x 1-3/8" 37-590 2068
26" x 1-1/2" 37-584 2100
27" x 1" 25-630 2145
27" x 1-1/8" 28-630 2155
27" x 1-1/4" 32-630 2161
27" x 1-3/8" 37-630 2169
27.5" / 650B x 1.50" 40-584 2079
27.5"/ 650B x 1.95" 50-584 2090
27.5" / 650B x 2.10" 54-584 2148
27.5" / 650B x 2.25" 57-584 2182
27.5" / 650B x 2.3" 58-584 2199
27.5" / 650B x 2.35" 60-584 2207
27.5" / 650B x 2.4" 61-584 2213
27.5" / 650B x 2.5" 64-584 2231
27.5" / 650B x 2.6" 66-584 2247
27.5" / 650B x 2.8" 71-584 2279
29" x 2.1" 54-622 2286
29" x 2.2" 56-622 2302
29" x 2.25" 57-622 2310
29" x 2.3" 58-622 2326
29" x 2.35" 60-622 2326
29" x 2.4" 61-622 2333
29" x 2.5" 64-622 2350
29" x 2.6" 66-622 2366
Live Chat support is currently unavailable while our HELPR Bot is under construction.
