Pair an ELEMNT, BOLT 1/2, or ROAM 1/2 to the ELEMNT companion app
This article describes the steps to pair a first or second generation ELEMNT computer to the ELEMNT app outside of the guided first time pairing process. For that process, just follow the on-screen directions.
If attempting to re-pair a computer to your ELEMNT app, you should first ensure that it was fully unpaired following the steps at Forget / unpair an ELEMNT, BOLT 1/2, or ROAM 1/2 from the ELEMNT app / phone.
Requirements
Steps to pair
Pairing an ELEMNT computer to the ELEMNT companion app requires actions on both the ELEMNT computer and in the ELEMNT app on your phone.
On the ELEMNT computer
  1. Navigate to the Menu screen (tap the left side button).
  2. Scroll down to Pair phone (right side buttons).
  3. Select Pair Phone (middle button).
  4. A large QR code should appear on screen. Set the ELEMNT on a flat surface.
ELEMNT ROAM menu with Pair Phone highlighted and PAIR above the middle button ELEMNT ROAM screen showing a QR code with Scan using companion app
ELEMNT app for iOS
  1. Open the ELEMNT app.
  2. Navigate to the Settings tab.
  3. Select Add new device or Pair a device as it appears.
  4. The app will turn on your phone's camera. Hold the phone above the ELEMNT so that the QR code is fully visible in the ELEMNT app.  Move the phone closer or farther away as necessary.
ELEMNT app for iOS Devices screen with the Add new device button highlighted ELEMNT app for iOS Devices screen showing No devices paired and a Pair a device button ELEMNT app Pair ELEMNT screen with the phone camera view open for scanning the QR code
  1. Select Pair to authorize the phone to pair with the ELEMNT when prompted.
  2. Select Allow to authorize the ELEMNT to receive notifications when prompted.
  3. The ELEMNT is now paired and will return to the Settings tab.
iOS Bluetooth Pairing Request prompt for ELEMNT ROAM with Cancel and Pair buttons iOS prompt asking to allow ELEMNT ROAM to receive iPhone notifications, with Don't Allow and Allow buttons ELEMNT app Settings tab showing ELEMNT ROAM DB26 connected with 74% battery
ELEMNT app for Android
  3. Select Devices in the top right corner.
  4. Select the (+) add icon in the bottom right corner.
  5. The app will turn on your phone's camera. Hold the phone above the ELEMNT so that the QR code is fully visible in the ELEMNT app.  Move the phone closer or farther away as necessary.
ELEMNT app for Android Settings tab with Devices in the top right corner ELEMNT app for Android Devices list with the (+) add button highlighted in the bottom right corner ELEMNT app for Android camera view for scanning the QR code, with pairing steps for each ELEMNT model below
  1. The ELEMNT is now paired.
  2. Select the X icon in the upper left corner to return to the Settings tab.
ELEMNT app for Android Devices list showing ELEMNT ROAM DB26 paired, with the X icon highlighted in the upper left ELEMNT app for Android Settings tab showing ELEMNT ROAM DB26 connected with 72% battery
Troubleshooting
  1. Move the phone camera farther from the ELEMNT. Often the correct distance is farther than feels natural.
  2. Make sure your mobile device's camera is clean and clearly focused on the computer.
  3. Keep the ELEMNT's screen clear of reflections and debris.
  4. Toggle your phone's Bluetooth off for 10 seconds and then back on from the iOS Settings > Bluetooth or Android Settings > Connections > Bluetooth, NOT the Quick tray controls.
    iPhone Control Center Bluetooth and Wi-Fi controls crossed out with a red prohibition sign
  5. Restart the ELEMNT and force close and re-open the ELEMNT app.
  6. If your computer has been paired to this app, but is not actively connected, follow all steps in the Forget / unpair an ELEMNT, BOLT, or ROAM from the ELEMNT app / phone article, and then re-pair using the full steps provided above in this article.
  7. Confirm that your ELEMNT computer is broadcasting a Bluetooth signal by downloading the LightBlue app from PunchThrough for iOS or Android. The LightBlue app is a Bluetooth scanner that will show any available Bluetooth connections in the area of the phone.
iOS specific notes
  1. It may be necessary to forget and repair your ELEMNT after an iOS update to re-establish a connection.
  2. On iOS 13: A new prompt to allow Bluetooth for individual apps was added to this iOS version, separately from the iPhone's main Bluetooth settings. If experiencing continued pairing issues, check the following:
    1. Open the main iOS Settings app.
    2. Scroll down to select ELEMNT.
    3. Ensure that Bluetooth is toggled on.
      iPhone home screen with the Settings app highlighted iOS Settings app list of apps with ELEMNT highlighted iOS Settings page for the ELEMNT app with the Bluetooth access toggle on and highlighted
  3. Last resort -- Reset your iPhone's network connections -- This will reset all Bluetooth and Wi-Fi connections.
    1. Navigate to iOS Settings > General > Reset or Transfer or Reset iPhone > Reset > Reset Network Settings and confirm.
      iPhone home screen with the Settings app highlighted iOS Settings app with General highlighted iOS General settings with Transfer or Reset iPhone highlighted
      iOS Transfer or Reset iPhone screen with Reset highlighted at the bottom iOS Reset options menu with Reset Network Settings highlighted iPhone Transfer or Reset screen with the Reset Network Settings confirmation prompt
