TICKR X Heart Rate Monitor Information and Setup
The Wahoo TICKR X is a heart rate monitor intended for use on or offline with your iOS or Android smartphone or tablet device, or even your GPS watch. In conjunction with your device, it uses Bluetooth 4.0 and ANT+ technology to track heart rate, calories burned, time, plus distance and pace information.
The TICKR X features built in memory enabling you to train without your smartphone and sync your data later. It has been optimized for runners and also monitors your running form in three dimensions, alongside other key running indicators such as cadence, vertical oscillation and ground contact time. It can also capture indoor cycling cadence workouts with the Wahoo Fitness app.
DOWNLOAD OUR APP
Wahoo Fitness App
The Wahoo Fitness app is designed to keep your TICKR X up to date and leverage your smartphone during running, cycling, or other workouts, delivering data-driven power that fuels your training and fitness goals. Get the app now to update your TICKR X and get cranking.
PRODUCT INFORMATION
DEVICE COMPATIBILITY
APPLE IOS
The Wahoo TICKR X is designed to work with any Apple device on iOS 11 or newer. To check the iOS version of your Apple device, check out  Find the software version on your iPhone, iPad, or iPod.
ANDROID
The Wahoo TICKR X is designed to work with the Wahoo Fitness app which supports most Bluetooth® compliant Android devices running Android version 6 or newer.
Note: Since Android devices vary widely, compatibility cannot be assured for all devices. Please download and install the Wahoo Fitness Android app from the Google Play Store before purchasing to ensure compatibility.
WINDOWS / MAC
The Wahoo TICKR X supports various Windows and Mac applications with Bluetooth and/or ANT+ capabilities. An ANT+ connection is strongly recommended on Windows PCs.
Note: the Wahoo Fitness app (required for important firmware updates) is only available on iOS and Android mobile devices.
DESIGN SPECIFICATIONS
  • Physical Dimensions (L x W x H): 2.5” x 1.5" x 0.2" (6.3cm x 3cm x 1cm)
  • Weight: .6 oz (17 grams) without strap, 1.7oz (48g) with strap
  • Battery: CR2032
  • Sweat Proof: Yes (hand washable strap)
  • Water Rating: IPX7 (waterproof up to 5 ft/1.5m)
  • Strap Length: Adjustable from 23" to 48” (58-122cm) stretched
IN THE BOX
  • Heart Rate Monitor
  • Adjustable soft strap
  • CR 2032 Battery (installed)
  • Quick Start Guide
TICKR X LED INDICATORS
The TICKR X Heart Rate Monitor uses a Blue and Red LED to give instant feedback to the user during the pairing process. These LEDs operate for about 30 seconds to conserve battery. The Red LED flashes each time a heartbeat is detected. The Blue LED represents your connection state and has three modes:
  • Slow Blink (about once every second): TICKR X is awake and not paired
  • 4x Flash: Occurs the instant a connection is made.
  • Quick Blink (about twice every second): TICKR X is paired to a device.
PRODUCT CARE & STORAGE
  • Wahoo recommends washing the strap with soap and warm water after use, then hanging to dry completely before next use.
  • Do not use strong chemicals or solvents on the strap or pod as these may reduce product longevity.
  • To store, simply unbuckle at least one side of the strap to prevent unintended battery drain.
SETUP
Download the Wahoo TICKR X Quick Start Guide as a PDF for instructions in English and other languages.
HOW TO WEAR THE TICKR X
  • Snap the sensor into one side of strap.
  • Adjust the strap to fit on your chest snugly, but comfortably.
  • Moisten the contact points on the back of the strap with saliva or electrode gel to improve conductivity.
  • Wrap the loose end of the strap around your chest and snap into place.
Back of the TICKR X strap with the two electrode pads to moisten highlighted
PAIRING TO THE WAHOO FITNESS APP
  1. Download the Wahoo Fitness app from the App Store.
  2. Open the Wahoo Fitness app. Make sure you have Bluetooth turned on.
  3. Wake up your TICKR X by wearing it on your chest (or touching both buckle terminals). The TICKR X wakes when heartbeats are detected.
  4. Select the Settings tab in the bottom right corner.
  5. Select the Sensors line item.
  6. Choose your TICKR from the available sensors.
  7. Be sure to install any updates, if available, then select Finish Setup to complete pairing.
Your TICKR X is now set up and ready for action! To use your TICKR X, simply select your workout type on the main workout tab and start a workout. The Wahoo Fitness app will remember this pairing in the future so that next time you can simply wake up your TICKR X and start a new workout to begin recording data!
STARTING A WORKOUT (IOS)
  1. Make sure the device has Bluetooth turned on so it can communicate with your TICKR X.
  2. Select what kind of workout you wish to do from the list of workout types using the slider.
  3. Select if you wish to have Audio Announcements turned on or off.
  4. Wake up your TICKR X by wearing it on your chest. The TICKR X wakes up when a heartbeat is present.
  5. Make sure the TICKR X is synced to your device. It will appear in the list of Linked Sensors for that workout profile with an indication of signal strength shown on the far right when it is connected to your device.
  6. Select the green "Start” button to begin the workout. Information gathered from your TICKR X will now start to be displayed on your device.
ENDING A WORKOUT (IOS)
  1. To end your workout, simply select the red "Pause” button.
  2. Select the red "Stop” button and either a) Discard Workout b) Save Workout or c) Return to Workout.
  3. If you elect to finish the workout, the Wahoo Fitness app will now display a summary of your workout.
PERFORMING AN OFFLINE WORKOUT (IOS)
  1. Put on the TICKR X strap to wake it up. There will be a red LED flash to indicate a heartbeat has been detected. Recording will automatically begin.^
  2. Perform your workout.
  3. When you next sync your device with the TICKR X it will prompt you to download the workout data from the sensor. The TICKR X will record up to 16 hours of workout data in offline mode.
^ If you wish to confirm the TICKR X is working during an offline workout, double tap it at any time & the LED will flash again to indicate it is awake (however, each double tap will place a marker in your workout history).
NOTE: If you have recorded offline workouts, they will appear in the History menu upon syncing with the Wahoo Fitness app. However, a workout less than 5 minutes in duration will not be synchronised. They can be downloaded manually in Sensors>TICKR X>Device Free Workouts.
STARTING A WORKOUT (ANDROID)
  3. Use the Pencil icon to make changes to your workout if required. e.g. Edit the Audio Announcements.
  4. Select the green "Play” button to open a new workout.
  5. Wake up your TICKR X by wearing it on your chest. The TICKR X wakes up when a heartbeat is present.
  6. Make sure the TICKR X is synced to your device. It will appear in the list of Linked Sensors for that workout profile with an indication of signal strength shown on the far right when it is connected to your device (button located in the top right corner).
  7. Select the green "Start” button to begin the workout. Information gathered from your TICKR X will now start to be displayed on your device.
NOTE: If a firmware update is available for your sensor, the Wahoo Fitness app will now prompt you to proceed with performing an update using the Wahoo app. If you do not, the update may be performed later. The free Wahoo app is required to perform firmware updates and is available from the Google Play Store.
ENDING A WORKOUT (ANDROID)
  • To end your workout, simply select the red "Pause” button.
  • Select the red "Stop” button and either a) Discard b) Save or c) Cancel.
  • If you elect to finish the workout, the Wahoo Fitness app will now display a summary of your workout.
PERFORMING AN OFFLINE WORKOUT (ANDROID)
  1. Select Workout history.
  2. Select the "Sync offline workouts” button located in the top right corner of the screen.
  3. Select "Continue” to import the offline workout data.
For more information: Please refer to the instructions page for the Wahoo Fitness app.
WANT TO CONNECT ANOTHER APP?
This product is compatible with a number of third party apps. However, each app connects to sensors a little differently. As a general rule: Open the compatible app you would like to use and find the settings. Look for "connect to sensor" or another similar option. You must connect each sensor separately for each app you use.
NOTE: Bluetooth devices can only pair to one app at a time. Make sure to close any background apps that may be using the sensor before connecting to a new app.
MAINTENANCE AND TROUBLESHOOTING
REPLACING THE TICKR X BATTERY
  1. Using a coin, remove the back casing of the device by inserting into the depression and turning anti-clockwise to the "unlocked” position.
  2. Replace the dead battery with a new CR2032 coin cell battery. For best performance and tracking, use a name brand battery such as Panasonic, Duracell, Energizer, etc.
  3. Replace the back casing and use the coin to turn clockwise to tighten to the "lock” position.
  4. Wahoo recommends using Panasonic coin-cell batteries or another name brand without a bitter coating for optimal performance and tracking.
STILL HAVING TROUBLE?
Please see our TICKR X Troubleshooting Article for steps to solve most common problems.
If you still need help, please Contact Wahoo Support here and we'll be glad to assist! You can also use the Settings > Info + Help > Send support email function from within the Wahoo Fitness app to attach a log with your query, allowing us to better answer your questions.
