KICKR HEADWIND Information and Setup
Download the Wahoo App
The Wahoo app keeps your trainer up to date and leverages your smartphone to record basic workout information, delivering data-driven power that fuels your training and fitness goals. Get the app now to update KICKR HEADWIND and get cranking.
  • Part Number: WFBKTR7US (US Version); WFBKTR7EU (EU Version); WFBKTR7AU (AU Version)
  • Motor Spec: 120v 60hz (US / Japan); 240v 50/60hz (EU / AU / UK Versions)
  • Dimensions (Legs Tucked): 16"L x 12"W x 19"H (40.6cm x 30.5cm x 48.3cm)
  • Dimensions (Legs Extended): 18"L x 12"W x 19"H (45.7cm x 30.5cm x 48.3cm)
  • Weight: 12 lb / 5.44 kg
  • Max Fan Speed: 30 mph / 48 kph
  • Connectivity: Bluetooth, Other
  • Adjustable Legs: Yes (2 Positions)
In the Box
Compatibility
The KICKR HEADWIND pairs to the Wahoo Fitness App via Bluetooth® for control from iOS and Android mobile devices, or connects directly to ANT+ enabled heart rate monitors like the Wahoo TRACKR, speed sensors like the Wahoo RPM Speed, temperature sensors, and all Wahoo Smart Trainers or other ANT+ enabled third party trainers. For more details, see the KICKR HEADWIND compatibility page.
  1. Always place the KICKR HEADWIND on a stable surface.
  2. Extend the legs to change the airflow direction. If placed directly on the ground, the rear legs can remain folded to angle air upwards. To position on a counter (or other elevated surface), extend the legs for a breeze that's more head-on.
  1. Plug KICKR HEADWIND into a power source. Do not modify or adapt the KICKR HEADWIND to plug into a different socket type than designed for (please contact support for exceptions).
  2. Press the power button to turn on and activate the fan. For more advanced settings, see Features.
Always follow these precautions when using the KICKR HEADWIND:
  • Always consult your physician before beginning or modifying any exercise program.
  • KICKR HEADWIND is intended for indoor use only.
  • Do not put hands or objects near moving parts of the KICKR HEADWIND.
  • Do not insert objects into the openings of the KICKR HEADWIND.
  • Only use the KICKR HEADWIND on a stable, level surface.
  • Keep water and moisture away from the KICKR HEADWIND at all times.
The KICKR HEADWIND can be controlled via the Wahoo App, the SYSTM app and offers a wide array of cooling options:
  • Manual - Control the HEADWIND's airflow using the buttons on the physical unit.
  • Standby - The KICKR HEADWIND broadcasts before and after the power button is pressed. This enables fully hands-free control and easy pairing.
  • Sensor Control - Control the KICKR HEADWIND's airflow using a variety of sensors.
  • Wahoo App Control - Control the KICKR HEADWIND's airflow remotely using buttons in the Wahoo App.
  • ELEMNT Control - Control the KICKR HEADWIND's airflow remotely using the interface on ELEMNT cycling computers.
Frequently Asked Questions
How do I update my KICKR HEADWIND's firmware?
What devices are compatible with KICKR HEADWIND?
What do I do if my sensor stops controlling my KICKR HEADWIND?
