KICKR CORE Firmware Release Notes
For firmware update process instructions, please see How to Update Firmware on KICKR, BIKE, CORE, SNAP, and ROLLR
KICKR CORE Firmware v1.5.36 - 28 October, 2024
  • Updated: Zwift protocol version.
  • Fixed: Virtual shifting would not disable when Zwift disconnects.
  • Fixed: Auto-spindown errors when using virtual shifting in specific scenarios.
    • In the previous firmware versions, there was an issue with the trainer calculating the correct spindown values during the auto calibration process in certain scenarios when also using Zwift Virtual Shifting. The conditions could result in the trainer reporting "ghost" watts (watts while coasting), and could result in a power offset throughout the ride. If you are currently experiencing "ghost" watts, this firmware update will not immediately fix the issue on its own, but having updated to the current firmware, the auto calibration process will fix the power offset over time without manual intervention. If you would like to resolve the power offset immediately, you can complete a manual spindown.
KICKR CORE Firmware v1.5.5 - 29 April, 2024
  • Fixed: 2000 watt power spike when switching between ERG/SIM
KICKR CORE Firmware v1.4.8 - 5 March 2024
KICKR CORE Firmware v1.3.17 - 22 January 2024
KICKR CORE Firmware v1.1.3 - 13 October 2021
  • Added: LED Sleep Mode - KICKR LEDs now turn off after 15 minutes of inactivity. Any flywheel movement or an active Bluetooth connection will re-activate LEDs.
KICKR CORE Firmware v1.1.1 - 1 June 2021
  • Added: Bluetooth FTMS support
KICKR CORE Firmware v1.0.13 - 11 June 2020
  • Fixed: Stability Improvements
  • Added: Cadence over ANT+ Power Profile
KICKR CORE Firmware v1.0.12 - 16 September 2019
  • Fixed a bug affecting speed and power after certain spindowns
KICKR CORE Firmware v1.0.11 - 4 September 2019
  • Added: Integrated cadence – simplifies setup by providing accurate cadence directly from your trainer, eliminating the need for external sensors.
  • Added: Powerful connectivity - new support for up to 3 Bluetooth® connections to ensure a trouble-free start to your workout.
KICKR CORE Firmware v1.0.10 - 10 June 2019
  • Minor bug fixes
KICKR CORE Firmware v1.0.8 - 23 April 2019
  • Improved power accuracy for wider range of spindown times
KICKR CORE Firmware v1.0.6 - 31 October 2018
  • Added: support for sending KICKR CLIMB status (current tilt and locked/unlocked mode) to third party apps via ANT+
  • Improved power accuracy over 25 MPH and 1000 watts
 KICKR CORE Firmware v1.0.4 - 26 September 2018
  • Improved power accuracy during high wattage sprints
KICKR CORE Firmware v1.0.2 - 27 June 2018
  • Initial release
