KICKR DESK v2 Product Info and Setup
This page applies to the KICKR DESK v2, released in fall of 2024.
  • NEW - hooks on legs can hold wheels or towels
  • NEW - two recesses for water bottles
  • NEW - USB cable holders
  • Fully adjustable - raise or lower the desk to sitting, riding, or standing position.
  • Built-in tablet and smartphone stands and holes to connect all your tech
  • Wheels for easy movement
  • Slip-resistant rubber desk surface
  • Base (Width x Depth): 28" wide x 30" deep (71 x 76 cm)
  • Desk Top (Width x Depth): 28" x 14" (71 x 36 cm)
  • Adjustable Desk Height (from floor): 35" to 47" (88 x 119 cm)
In the box
  • Desk table top
  • Non-slip table mat
  • Adjustable legs
  • Lower frame
  • 2 caster wheels
  • 2 fixed wheels
  • Assembly hardware
  • 2 hex assembly wrenches
Assembly Guide
View and download a PDF of the KICKR DESK v2 Assembly Guide here for images of assembly.
Assembly
  1. Insert large wheel (G) into the extensions at the rear of one side of the base and use the 5mm wrench tool (hex key) to secure it with long bolt (A) to approximately 10Nm. Repeat for other side of the base.
  2. Thread a lock washer (E) onto each caster wheel (F).  Then use the open end wrench tool to gently thread a caster wheel into the front section of the base.  The caster wheel uses standard right hand thread.
  3. Taking care not to pinch a finger, insert one side of the base into the the front section of the base. Then use the 5mm wrench tool to secure the two base sections together with one of the 8x shorter bolts (C) and washer (B). Tighten to approximately 10 Nm. Secure each side with 2x bolts (C) and washers (B).
  4. Extend each leg fully by pressing the black button at the top of each leg and carefully pulling the upper to the full height.  Taking care not to pinch a finger, slide the leg lower over the frame extensions on the base so that the bottom edge of the leg sits flat against the top of the base.  Use the 5mm wrench tool to install one of the shorter bolts (C) and washers (B) into the front and back of each leg to secure the legs to the base. Tighten to approximately 10 Nm. Repeat for the other leg.
  5. Gently slide the desk top  over the top of both legs , so that the desk top sits horizontal to the floor. Use the 4mm wrench tool (hex key) to install one of the 2x smaller bolts (D) into the back of the vertical extensions of the desk top to secure the desk top to each leg.
  6. Move the desk to place where you intend to use it.  Use the open end wrench to adjust the height of the caster wheels (F) to level the desk top, and then use the lock washers (E) to secure the caster at that height.
  7. Remove the adhesive sticker covers from the backs of the cable guides and affix them along the legs or base wherever you would like to run the charging cables for your preferred devices.
Notes
  • The DESK is designed to hold a maximum of 50 pounds / 23 kilograms, with the weight distributed across the desk top. Applying that weight in a small area off center creates a tipping risk.
  • The DESK wheel holders on each leg are designed to hold a maximum of 8.8 lbs / 4 kilograms.
