KICKR DESK Product Info and Setup
This page applies to the original KICKR DESK.
  • Fully adjustable - raise or lower the desk to sitting, riding, or standing position.
  • Built-in tablet and smartphone stands and holes to connect all your tech
  • Wheels for easy movement
  • Slip-resistant rubber desk surface
  • Base (Width x Depth): 28" x 30" (71 x 76 cm)
  • Desk Top (Width x Depth): 28" x 14" (71 x 36 cm)
  • Adjustable Desk Height (from floor): 33"" to 48"" (84 to 122 cm)
In the box
  • Desk table top
  • Removable non-slip table mat
  • Adjustable legs
  • Lower frame with Wheels
  • Hex assembly wrenches (2)
  • Assembly Instructions
Assembly Guide
View and download a PDF of the KICKR DESK v1 Assembly Guide here for images of assembly.
Assembly Description
  1. Extend each leg (B) fully by pressing the blue button at the top of each leg and carefully pulling the upper to the full height.
  2. Slide the leg lower (B) over the frame extensions on the base so that the bottom edge of the leg sits flat against the top of the base (C).  Use the 5mm hex key to install one of the 4x larger bolts (E) and curved washers (F) into the front and back of each leg (B) to secure the legs to the base.
  3. Gently slide the desk top (A) over the top of both legs (B), so that the desk top sits horizontal to the floor. Use the 3mm hex key to install one of the 2x smaller bolts (D) into the back of the vertical extensions of the desk top (A) to secure the desk top to each leg (B).
