The ROLLR is designed to function in Power Meter Connect mode (where the ROLLR connects to POWRLINK Zero pedals or another ANT+ power meter) to transmit power and cadence data to a controlling app or device, allowing for dynamic resistance on the ROLLR in a ride simulation or ERG mode workout in a variety of ride simulation and training apps.
The ROLLR can be used without a power meter paired in certain ride simulation apps, like Zwift. For more information on that, see Use ROLLR without a power meter (virtual power).
Pair a power meter to ROLLR
- Pair your KICKR ROLLR to the Wahoo app for iOS or Android like any other sensor, smart trainer, or smart bike.
- Once paired, select the ROLLR from the My sensors list in the Devices tab.
- If no power meter is paired, select No power meter.
- If a power meter is already paired that you wish to change, select the power meter already paired.
- Any ANT+/Bluetooth power meters broadcasting signal in the area will appear under Available power meters. POWRLINK Zeroes will be listed by name. All other ANT+ power meters will be identified by their 5 digit ANT+ ID, which is often found on the side of the power meter itself. Select your desired power meter.
- If a power meter is already paired, select the power meter under Paired power meter to de-select it.
- Once selected, the power meter will appear under Paired power meter and will be automatically locked to the ROLLR. It will remain locked unless replaced using the process above.
