Identify a KICKR trainer
Part number Identification
KICKR models can be identified by the Part number on the white sticker on the drive side of the flywheel plastics.
Model Part number
KICKR v6 (2022) WFBKTR122
KICKR v5 (2020) WFBKTR120
KICKR v4 (2018) WFBKTR118
KICKR v3 (2017) WFBKTR117
KICKR v2 (2016) WFBKTR116
KICKR v1 (< 2016) WFBKTRNR11
KICKR MOVE WFBKTR123
KICKR CORE WFBKTR4
KICKR SNAP WFBKTR3
KICKR ROLLR WFBKTR9B
To locate the white sticker on other products, see Where is the serial number on my Wahoo product?
Visual Identification
If the sticker is obscured or missing, you can visually identify KICKR Trainers using the following distinguishing features.
kickrv6-profile-300.png kickrmove-profile-300.png core-profile-300.png snap-34-300.png rollr-profile-300.png
KICKR MOVE CORE SNAP ROLLR
  • The trainer base has 3 legs. The two outer legs can be folded in toward the center using a button.
KICKR MOVE
  • The MOVE shares the same base configuration as the KICKR, but a larger lower body and main arm with a track that allows the upper body to move fore/aft.
KICKR CORE
  • The trainer has two legs, with feet that sit perpendicular to the legs.
KICKR SNAP
  • The trainer has an open frame with a cam clamp and a roller unit with an adjustment knob to receive a bike with the rear wheel on.
  • The trainer is a pair of rollers, with a triangle front arm to steady the front wheel.
KICKR Versions
ALL KICKRs
v1 (-2015)
  • The drive side hub interface has a threaded axle that will only accept a quick release skewer.
  • The carry handle is black and low on the spine of the trainer.
  • The surface of the flywheel is flat.
v2 (2016)
  • The drive side has a threaded axle that will only accept a quick release skewer.
  • The carry handle is gray and horizontal to the ground.
  • There is a flat plastic top cap above the bike hub interface.
v3 (2017)
  • The drive side will accept a thru axle.
  • There is an angled plastic top cap above the bike hub interface.
v4 (2018)
  • The surface of the flywheel is recessed.
  • The top surface above the hub interface is painted metal.
  • There is NOT a direct connect port above the power plug.
  • The outer legs have hard plastic feed.
v5 (2020)
  • There is a direct connect port above the power plug.
  • The outer legs have large multi-part feet with replaceable rubber inserts.
  • The LED lights are labeled with Bluetooth and ANT+ symbols.
v6 (2022)
  • The outer legs have large multipart feet with replaceable rubber inserts.
  • The LED lights are labeled with Bluetooth and Wi-Fi symbols.
Compare currently available KICKR trainers [@wahoofitness.com].
