This article addresses Bicycle frame compatibility for KICKR smart bike trainers. If looking for KICKR MOVE or CORE, please see the bicycle frame compatibility article for KICKR MOVE or KICKR CORE.
Please also review the article on Drivetrain Compatibility for KICKR, CORE, and MOVE trainers.
Because of the wide variety of bicycle makes and models, it is not possible for Wahoo to guarantee the KICKR’s compatibility with all bicycles matching these parameters. To fully ensure compatibility, we recommend visiting a local Wahoo retailer to test your bicycle’s fit before purchasing.
Please note the Known Bike Incompatibilities listed below. While Wahoo has conducted tests on KICKR safety and compatibility with certain bikes, you are ultimately responsible for ensuring that your bike frame is compatible with the KICKR trainer such that bicycle frame damage does not result from using the KICKR trainer.
Before riding for the first time, we suggest gently mounting the bike frame and confirming that the bike is secure, squarely in contact with the mounting points, does not exhibit excess movement, and that no part of the bicycle frame contacts the frame or moving parts of the trainer except at the designed contact points. If no concern is found, we suggest paying attention for abnormal movement or sound during the first ride. If found, stop riding and contact our support team to review the installation.
Wahoo Fitness strongly discourages altering trainers to fit bikes that deviate from the following specifications by (including, but not limited to) grinding-down components, adding washers, or improperly reversing spacers, as these actions increase inherent risk and may void your warranty. Wahoo Fitness is not liable for any damage or injury related to improper installation, modification, or misuse of hardware.
1. Supported Wheel Sizes
| Wheel Size | ISO | Description |
| 24 inch | 507mm | childrens |
| 26 inch | 559 mm | legacy mountain |
| 650C | 571 mm | legacy tri, road |
| 650B / 27.5 inch | 584 mm | gravel, mountain |
| 700C | 622 mm | road, cross gravel, hybrid |
| 29 inch | 622 mm | mountain |
Any size not listed in the above table is not compatible.
2. Supported Rear Hub Standards
| Type | Standard | Description | Uses | Also Requires |
| Quick Release | 10x130mm | common road |
QR axle, included |
| 10x135mm | hybrid, legacy mountain |
QR axle, included | |
| Thru Axle | 12x142mm | common road, cross, gravel, Standard mountain |
Your bike's thru axle |
| 12x148mm | Boost mountain |
If not found in the list above, your bike is not compatible. Specifically the following hub standards and bike types are incompatible:
3. Unsupported Rear Hub Standards/Bike Concepts
| Quick Release | 10x120mm | track |
| 10x126mm | legacy road, < 8 speed | |
| 10x141mm | Boost QR | |
| Thru Axle | 12x135mm | legacy Specialized SCS |
| 12x157mm | SuperBoost mountain |
4. Known Bike Incompatibilities
The following bikes are not compatible with any KICKR or CORE.
- Bianchi Aria Disc: 2021-22
Bianchi Infinito CV Disc: 2021-22
Bianchi Oltre XR3 Disc: 2021-22
Bianchi Oltre XR4 Disc: 2021-22 - Canyon Ultimate with rim brakes [The disc brake version is compatible.]
- Rose Reveal Plus [or any bike using the Mahle X20 rear hub drive interface].
- Specialized Crux Expert Evo: 2015
- Trek Domane+ ALR-5: 2023-2025 [or any bike using the Trek 141 QR/bolt on standard]
The following bikes are not compatible with any KICKR before version 4 (2018):
- Cervelo Disc frames: All
Giant Propel Disc 2021+
Giant TCR Disc 2021+ -
Lauf Siegla
Lauf True Grit - Rondo Ruut AL2: 2021+
Trek Domane 2020+
Trek Madone 2020+
Trek Checkpoint Carbon 2021+
Trek Emonda 2021+
Trek Top Fuel 2021+ - Ventum thru axle frames: All
5. Conditional compatibilities
The following bikes are compatible only when the following conditions are met:
Electric Bikes (eBikes) can be used on a KICKR or CORE when:
- The bike uses one of the supported rear hub mounting standards described above in 2.
- The motor is off and not providing any assistance.
- The combined weight of rider, bike, and battery is below the stated limit of 250lbs / 113 kg.
- The manufacturer has confirmed no concerns regarding the bike’s integrity when used on a stationary trainer.
Lauf Siegla
Trek Domane 2020+
Trek Madone 2020+
Trek Emonda 2021+
- Can be used on a KICKR v4 or later when used with updated thru axle adapters.
- The bikes listed above have frame interfacing issues with the original stock thru axle adapters shipped with some new units of KICKR v5 (2020), some new units of KICKR CORE, and all new units of KICKR v4. Certified reconditioned units of KICKR v4, v5, and CORE units may also have these original adapters.
- The updated adapters were produced to resolve compatibility issues for these frames with KICKR v4 (2018) and later, and all models of KICKR CORE. They are available for purchase on our website.
- KICKR v6 (2022) units are shipped with the updated adapters. Certified reconditioned units of KICKR v4 and v5 also may ship with the updated adapters.
In order to identify which adapter set you have, look for a taper or bevel in the drive-side spin cap (parts # 3 [original] and 7 [updated]).
The new adapters require installation of a new drive-side freehub lock nut (included in the kit), for both Shimano HG/SRAM/Campagnolo and SRAM XDR freehubs. Installation instructions can be found here. For any further questions, please reach out to our customer support team.
