Bluetooth troubleshooting [Android]
1. Ensure Location Services are on
Bluetooth connections on Android require Location Services to be enabled. Please check your system settings.
2. Ensure all app permissions are granted
Bluetooth connections on Android require the location permissions to be granted to the Wahoo app. Please ensure all permissions are granted in the system settings (Android Settings > Apps > Wahoo > All permissions enabled).
3. Ensure battery optimizations are disabled for the app
Android phones running Android 6.0 or later will kill background apps automatically in certain circumstances.  This may affect workout recording and/or device and sensor connectivity.  Please ensure the Wahoo app is excluded from Android's "battery optimization" list. Note that some Android devices refer to this as "unmonitored apps" under battery settings.
4. Pair with the app, not the Android Bluetooth Manager
Wahoo trainers and sensors should be paired with the Wahoo app (or whatever third party app you are using, not the Android system Bluetooth manager in the system settings.  Make sure the device is not paired with the Android Bluetooth settings, then retry pairing through the Wahoo app.
5. Ensure an exclusive connection
Some Wahoo devices are only able to maintain one Bluetooth connection at a time.  Ensure other apps (including apps on other phones) are disconnected from your Wahoo device. Disable Bluetooth on (or power down) any previously paired phone, tablet, or Apple TV and force close any background apps which have previously paired to guarantee they are not maintaining a connection and blocking the one you intend.
6. Forget and re-discover
Please try ‘forgetting’ the saved device in the Wahoo app and re-pairing -- navigate to the Home > My Sensors page in the Wahoo app and choose (+) or Pair Sensor. Select your sensor from the list to save/pair it.
Wahoo app Home screen with the My sensors bar for Indoor Cycling highlighted at the bottom Wahoo app sensor view with the My sensors heading and its (+) add button highlighted Wahoo app Searching for sensors list with KICKR CORE FBC0 highlighted Wahoo app message: KICKR CORE FBC0 has been paired!, with a Done button
7. Check for interference
Wi-Fi can sometimes interfere with Bluetooth connections. Try disabling Wi-Fi and connecting to the Wahoo device again. Move away from Wi-Fi, Bluetooth, and other signals/devices which can cause interference like Chromecasts, GoPros, and power lines. For further potential sources of interference, see Signal Interference with Wahoo Smart Trainers.
8. Check for background Bluetooth sync features from other apps
It has been observed that apps that have background Bluetooth sync features such as FitBit and Pebble can interfere with a stable Bluetooth connection. Please disable all background Bluetooth features on apps like these.
9. Toggle Bluetooth
Turn off Bluetooth in the Android system settings for 30 seconds, then turn it back on. If Bluetooth does not switch off and on properly, reboot your mobile device.
10. Reboot
Try rebooting your Android device and, if possible, the Wahoo device. For Wahoo smart trainers, ensure you disconnect the power for at least 30 seconds.
11. Reset Android Bluetooth app
In the Android system settings, go to the Apps section and tap the 3 dots in the top right corner to select "Show system" and find the "Bluetooth" or "Bluetooth Share" app. Select  Storage > and Clear Data on these apps to reset them, then reboot.
12. Confirm the sensor is broadcasting a Bluetooth signal
Still unable to pair? Check that your sensor is transmitting a Bluetooth signal by downloading the free LightBlue Explorer app from the Google Play Store. Make sure your sensor is on, awake, and illuminated (if applicable), then open the app to find if it's listed.
If your sensor remains unlisted for longer than a few minutes, please contact support.
If your sensor is listed in the LightBlue Explorer app but you're still unable to pair, try the above steps again, as this is indicative, of an app/phone settings issue.
13. Contact Wahoo Support
Regardless of if you can find your trainer or sensor in LightBlue Explorer, Wahoo Support is here to help. If you have questions or need further help, please submit a support request.
