Drivetrain Compatibility for KICKR and KICKR MOVE
This article applies to KICKR version 4 (2018) and newer and KICKR MOVE. In order to identify your trainer, please see this Wahoo wheel-off smart trainer identification article.  In order to confirm if your bicycle's frame is compatible with a KICKR or KICKR MOVE, please see the bicycle frame compatibility articles for KICKR or KICKR MOVE.
Compatibility Principles
Drivetrain compatibility with a KICKR or CORE requires that a cassette to be installed on the trainer is compatible with:
  • your bicycle's drivetrain in:
    • cog count (how many cogs/gears on the rear sprocket),
    • min/max tooth count (how many teeth on the smallest and largest cogs), and
    • in some cases, your drivetrain's brand (as some brand chains/derailleurs will only interface properly within that brand's system).
  • a freehub body (the component of the trainer, or a wheel, onto which the cassette is mounted).
Using a cassette incompatible with your bicycle’s drivetrain can result in damage to the cassette or other parts of your drivetrain.
Most current and recent bicycles have a cassette with between 7 and 13 cogs.  Due to the similarity in cassette cog spacing within 8, 9, 10, and 11 speed drivetrains across brand (brand A 9 speed with brand B 9 speed, NOT 9 speed with 11 speed), many riders have found that many drivetrains can be used with a different brand cassette with the same number of cogs (brand A 11 speed drivetrain with brand B 11 speed cassette) such that many 11 speed bikes can be used with the stock cassette installed on a KICKR, with only minor adjustments to a rear derailleur. Similarly, many other 8, 9, 10, and 11 speed bikes can be used with the stock cassette provided with some COREs.  For the most precise shifting, please refer to your drivetrain manufacturer's documentation for acceptable compatibility.
If your bicycle's cassette has a different number of cogs than the stock cassette provided with  a KICKR or some COREs, your brand of drivetrain is not compatible with a Shimano standard for that cog count, or if you wish to use a wider range cassette (with a larger low cog) that more closely matches your bicycle's current cassette, you will need to:
  • purchase another cassette that matches your drivetrain in cog count, brand, and min/max tooth count from a third party.
and may also need to:
  • install a 1.8mm cassette low spacer (behind the cassette)
  • purchase and install a 4.5mm cassette low spacer (with the 1.8mm spacer behind the cassette) from a 3rd party (7 speed only)
  • purchase a different freehub body (some SRAM and any compatible Campagnolo drivetrain -- see below)
Supported Drivetrain Systems
To support the broadest range of modern drivetrain standards, Wahoo offers 3 freehub bodies. These are:
  • The stock Shimano HyperGlide 11 (HG 11) compatible freehub body is compatible with Shimano HG, SRAM PowerGlide (PG), and other drivetrain cassettes with 7-12 cogs. This is included with KICKRs and CORE.
  • A SRAM XDR compatible freehub body, sold separately, for SRAM XG and XS cassettes for Eagle, Eagle AXS, Eagle Transmission, AXS, and AXS XPLR drivetrains with 11-12 cogs.
  • A Campagnolo compatible freehub body, sold separately, for most Campagnolo cassettes with 10-12 cogs. See below.
Known Incompatibilities
The following drivetrains are NOT COMPATIBLE with KICKR or CORE:
  • Shimano
    • Micro Spline 12 speed mountain or gravel (requires an unavailable freehub body)
      • Workaround for 12 speed Shimano mountain drivetrains -- Many users have found they can be used with:
        • the stock Shimano HG 11 compatible freehub body and
        • a SRAM PG-1210 or 1230 12-50t cassette purchased from a third party OR
        • the SRAM XDR freehub body, sold separately, and
        • the 1.8mm cassette low spacer included with the KICKR or CORE
      • Workaround for new GRX 12 speed drivetrains, use with:
        • if the cage will support 50 tooth low cog, use the SRAM PG-1210 or 1230 cassette.
        • if it will not, use the 105 12 speed 11-34 (CS-R7101-12) or 11-36  (CS-HG710-12) cassette
  • Campagnolo
    • 7-9 speed drivetrains (legacy design not supported by current Campagnolo freehub body design)
    • 10 speed drivetrains with older 8-arm style cassettes
    • 12 speed Super Record Wireless drivetrains (requires unavailable N3W freehub body)
    • 13 speed Ekar drivetrains (requires unavailable N3W freehub body)
  • Rotor
    • 13 speed drivetrains
Compatibilities
The following drivetrains are COMPATIBLE with KICKR or CORE when the conditions noted below are met.
Brand Freehub Type Cassette cog Count 1.8mm spacer Also Requires Notes
Shimano (HG) HG 11 7 Yes
  • Cassette
  • 4.5mm spacer
    8-10 Yes
  • Cassette
    11 No
  • Stock install
Cassette > 32t requires 1.8mm spacer
    12 No
  • Cassette
SRAM (PG) HG 11 7 Yes
  • Cassette
  • 4.5mm spacer
    8-10 Yes
  • Cassette
    11 No
  • Stock install
SRAM [PG] SX/NX Eagle   12 Yes
  • Cassette
SRAM [XD] (Eagle, Eagle AXS, Transmission) XDR 11-12 Yes
  • Wahoo XDR freehub
  • Cassette
SRAM PG-1130/1210/1230 are compatible with stock freehub. Will lose 10t small cog.
SRAM [XDR](AXS, AXS XPLR) XDR 12 No
  • Wahoo XDR freehub
  • Cassette
Campagnolo Campagnolo 10 No
Campagnolo HG 11 or Campagnolo 11 No
  • Stock Install OR
  • Wahoo Campagnolo freehub
Campagnolo drivetrain is compatible with stock cassette on KICKR. If Campagnolo cassette is desired, Wahoo Campagnolo freehub is required.
Campagnolo   12 (NOT Super Record Wireless) No
  • Cassette
ROTOR HG 11 12 No
  • Cassette
FSA HG 11 11-12 No
  • Cassette
Microshift HG 11 8-10 Yes
  • Cassette
    11 No
  • Cassette
BOX HG 11 7-11 Yes
  • Cassette
