Add a speed, cadence, or heart rate sensorsto gather more information during your workout and get a more comprehensive report about your ride. The MINI is only compatible with Wahoo Sensors.
To pair a new sensor
- Wake up your sensor., try giving it a shake or spin the tire / crank.
- Press and release both the left and right button simultaneously on ELEMNT MINI to open the Settings menu.
- Select the Sensors menu.
- Select the Find Sensors function.
- Place the sensor close to the ELEMNT MINI and you’ll be prompted to save after a few seconds.
To get you started, the ELEMNT MINI comes with the RPM SPEED sensor. Set your Tire Size (in millimeters) when prompted for more accurate results.
NOTE: If you start your workout without waking up your additional paired sensors, you can still wake them and they will begin to send data.
