KICKR SNAP First Troubleshooting
While specific common challenges are addressed in our SNAP Troubleshooting Guide, the following practices are good first steps for most KICKR SNAP issues.
Setup + Warm up
  • Make sure the unit is plugged in, the connection to the power brick is secure, and the green light on the power brick is illuminated
  • Inflate your tire to manufacturers recommended PSI as printed on the sidewall of your tire - most 700c road tires require around 110 PSI
  • Check the tension on the rear wheel by loosening the blue tension knob completely, tightening until the roller contacts the rear wheel, then continuing to tighten two additional full (360º) turns
  • Ride the KICKR SNAP for 10 minutes to warm it up
Perform a Spindown
  • Pair the KICKR SNAP to the Wahoo app
  • Confirm that your firmware is up to date
  • Perform a spin down
  • If you experience significant tire slipping or the spindown is unusually long (over 45 seconds), tighten the blue tension knob one quarter turn and perform another spindown, repeating as necessary.
  • If the spindown is unusually short (under 10 seconds), loosen the blue tension knob one quarter turn and perform another spindown, repeating as necessary
  • If you have an older KICKR SNAP (these do not have external Bluetooth and ANT+ LEDs as shown in the image below), loosen the roller a quarter turn if spindown times are shorter than 10 seconds, or tighten a quarter turn if spindown times are longer than 15 seconds
Additional Steps
If these steps don't resolve your issue, please take a look at our SNAP Troubleshooting Guide.
