Compatibility: New ELEMNT BOLT, New and original ELEMNT ROAM
Requirements:
- iOS/Android Companion App 1.62.0+
- ELEMNT (new BOLT, both ROAM) Firmware: 15469+
Date Available: 10/31/22
What are Summit Segments?
- Routed climb detection
- When a route is loaded, the ELEMNT will detect significant climbs along the route and generate a list of upcoming climbs.
- Summit Segments automatically detects climbs on a preloaded route, giving you in-depth information about upcoming, in-progress, and completed climbs. You'll see the number of climbs, when they occur, length, and average gradient.
- New Climb Segments Page
- This list of detected climbs will be provided on a new Climb page. Initially all upcoming climbs will be listed with distance to climb, length of climb, and average grade of climb. As a climb is begun, that climb will be listed as 'In Progress', and later 'Completed'. This page will exist as a subpage within the Elevation page flow and you can toggle between the two using the left button on the face of the computer.
- Climb Segment notifications
- As you approach a climb, you will be shown notifications at the bottom of the screen alerting you to the distance to climb, length of climb, and average grade of climb. If not on the climb page, notifications will also be provided for starting the climb, approaching the end of the climb, and finishing the climb.
- New Summit Live Segments Page
- Once you've started a climb, a new in-climb page will appear, with data fields for:
- time elapsed in the climb
- vertical distance to go
- distance to go
- current grade
- estimated total time to complete climb
- When enabled, you will be able to toggle between this page, the Summit Segments page, and the Elevation page using the left button on the face of the computer.
How is this feature enabled/controlled?
- The Segment pages, Segments Live page (and automatic page change), and page notifications are enabled by default, but these subfeatures can be toggled individually on the Settings page of the ELEMNT companion app at Settings > RIDE > Summit Segments.
How are climbs defined?
- According to current parameters, a climb segment must be both at least 500 meters in distance and at least a 3% average grade. For example, a 490 m segment with a 5% average grade will not be considered a climb due to insufficient distance, and a segment that is 1 km with a 2.5% average grade will not be considered a climb due to insufficient average grade.
How do Summit Segments interact with Strava Live Segments?
- When Strava Live Segments and automatic page changes have been enabled, and a Strava Live Segment that has been starred overlaps with a Summit Segment, the Strava Live Segment and associated pages will take precedence over any Summit Segment notifications or pages.
