Speed sensors
Speed sensors are currently supported only on Windows/MacOS with a compatible USB ANT Dongle.(RGT does not support ANT connections done through mobile devices that are ANT compatible, or any other ANT mobile attachments).
Dual speed and cadence sensor are not currently supported. The sensor has to only output speed data (function only as a speed sensor) in order for RGT to be able to pair to it successfully.
Some events will not support Virtual Power. Please check event details and look for ‘Allow virtual power: on’ in the event description.
  • Please make sure you have an ANT USB Dongle plugged in and follow these instructions to confirm it is being detected by RGT: Pairing with ANT
