Pairing with Bluetooth
There are two possible way to connect to a BLE device:
  1. By using the RGT App.
  2. By using the RGT Remote App.
BLE service does not work while the RGT App is in the background (out of focus).
RGT App and RGT Remote App on the same device is not supported.
Connecting to a BLE device using the RGT App
Please make sure that BLE is enabled on your device, check permissions to make sure that RGT App also has access to BLE services (location services for Android).
Menu → Sensors → Toggle the BLUETOOTH LE switch to ON
Once the devices are found, toggle the switches for Power/Cadence/Control to ON
Connecting to a BLE device using the RGT Remote
Please make sure that BLE is enabled on your mobile device, check permissions to make sure that RGT App also has access to BLE services (location services for Android).
When MOBILE BLE is in use, the BLE is handled by the mobile device where the RGT Remote App is installed.
With the RGT Remote App open on your mobile device, toggle the MOBILE BLE switch to ON
Speed sensors over BLE are not currently supported, however they are supported over ANT:
Speed Sensors
