ANT USB Dongle - Is required to be plugged into your screen device (MacOS/Windows) in order for RGT to be able to connect to your ANT compatible device (we do not support ANT connections done through mobile devices that are ANT compatible, or any other ANT mobile attachments).
Instructions
Start RGT Cycling, navigate to Menu → Sensors and set the ANT+ toggle to ON.
Connect to the devices seen in the list by setting the according device toggle switches to ON.
If the ANT is not detected this means another resource is likely using the ANT service. Please end all other background applications that are using the service and re-start RGT Cycling.
CONNECTING TO JUST THE POWER OF A TRAINER, OR TO A POWER METER
(where you want to see just the power of the trainer and maybe have another app control the trainer's resistance) please only toggle the switch under POWER category to ON:
Using Virtual Power in Wahoo RGT
ANT USB Driver:
In case your ANT USB Dongle is not being detected by Windows at all, please download the following driver and try manually installing it.
To install the driver manually on Windows 10:
-Download and unzip the driver for your device (above driver is from the thisisant website).
-Open Device Manager
-Right-click on the ANT USB device
-Click 'Update Driver Software...'
-Click 'Browse my computer for driver software' option in the 'Update Driver Software' dialog that appears
-Click 'Let me pick from a list of device drivers on my computer'
-Click the 'Have Disk...' button
-Browse to the folder containing the unzipped driver package files
-Select the '.inf' file in that directory and click 'Open'
-Click 'OK'
-Click the ANT model shown in the list and press 'Next' (Note: If you are installing unsigned Si Labs driver you will likely need to accept the unsigned driver warning and additionally disable driver signature enforcement)
-The driver should then install and work correctly
