RGT supports all BLE FTMS and ANT FE-C compatible trainers. BLE and ANT+ heart rate monitors and power meters are compatible. ANT+ Cadence and Speed sensors are compatible on the desktop apps only.
The following devices are known to be incompatible with RGT:
Bkool PRO - Not supported over BLE (Bkool trainers and BLE)
CycleOps PowerSync - Trainer is not compatible with ANT+ FE-C so RGT will not be able to control the trainer resistance
CycleOps Pro 400, 410, 420 - These trainers use a proprietary ANT+ protocol. Newer CycleOps 420 versions use the open ANT+ communication standard and should be compatible with RGT. Users with these versions, please contact CycleOps and ask if there's any firmware update available to make their trainer compatible with the open ANT+ standard.
Wahoo Kickr first generation - Firmware update is required to make this trainer compatible with RGT. Instructions can be found here for Android users and here for iPhone users.
- Wahoo KICKR Bike and Wahoo KICKR CLIMB will not respond to elevation changes when in ERG mode.
- Wattbike shifter buttons do not change gears while on ERG mode.
- CompuTrainer (https://perfprostudio.com/CTSmart.aspx this app can possibly make your computrainer compatible with RGT unofficially, it has not been tested nor we will provide support for it, use at your own discretion)
